Magneplanars and EnABL
Hi all,
It is now your turn to argue about and debunk and try EnABL.
I recently had an opportunity to begin the process of applying EnABL to a pair of Maggie 2.6r speakers. I have no intention of touching any of the driver surfaces. All work will be applied to the side trim panels on the front (already finished), across top and bottom, though the exact location is up for debate, and on the backside, in locations that correspond to the front side treatment.
For a general description of the process and a template to show you spacing and also where the EnABL blocks go here.
http://www.diyaudio.com/forums/showthread.php?postid=1900327#post1900327
These EnABL blocks were made from 0.003" thick clear acrylic contact paper, with a stick and remove adhesive, so they can be removed without damage to the wood trim, should you want to do so.
Bud
G'day Ed,
Thankyou for your reply!
Your description of 'riotous' debate regarding EnABL is probably a little conservative. :)
Logically, the descriptions of the audible changes EnABL brings are difficult to comprehend.
I have spent the last 18 months exploring EnABL on fixed surfaces - ports, baffles, vents, inside cabinets and even room corners. My work is simply an extension of Bud's invention.
EnABL is effective, the audible changes are real and attainable using ridiculously simple materials and a process that is completely reversible.
So, I would like to make you a proposition.
Let's discuss a 'hypothetical' EnABL treatment for your Maggies.
I will describe in detail how one might (hypothetically) EnABL the fixed surfaces based on your particular speakers.
There is no requirement for you to actually do any of this or report your listening impressions if you do - because it's just hypothetical.
What do you say?
Alex
OK then, hypothetical debate is usually a healthy excersise.
I have a pair of SMGa speakers, that I stripped and rewired using materials supplied by Magnepan last year. The intention was to restore them to original condition, or as near as I could manage. They now seem to have settled down, and present music very nicely.
I don't understand how EnABL additions to fixed surfaces will alter or improve what I hear. The wooden sides are well damped - they are fixed over the fabric "sock" that covers the baffle.
More later - have to go to work!
Ed
My current thoughts on how this works is here:
http://www.diyaudio.com/forums/showpost.php?p=1901191&postcount=402
So the wooden sides are on top of the fabric.
Can you post a photo with the outside edge dimensions and the dimensions around the edge of the driver?
I can then draw up a picture of a hypothetical application.
Alex
PS: Found this pic of a 'sockless' SMGa...
frugal-phile™
Joined 2001
So far that is a mystery to everybody. But the empirical evidence cannot be discounted, further investigation is required (and slowly happening).
I am encouraged by what i am reading in Toole's latest book (i'm going to paraphrase since i can't find a direct quote quickly, but he says it over & over again): "a microphone and an analyzer does not have nearly the capability of 2 ears and a brain".
dave
Alex
Ha, yes they're less than attractive without their socks on, but then so are many of us.
No photo, but the baffles are 18" wide x 48" tall, within which the driver aperture of 9.5" x 39" is centered across the width, but 6" from the bottom, and 3" from the top. The gap between the inside edges of the wooden side is approx 17.5", and these are proud of the baffle face by about 1/2". The wood sides are 3/4" by 2" and give the assembly considerable extra rigidity.
I read quite a lot from the threads regarding EnABL, its application to transducer surfaces and its application to baffles/enclosures etc. I will admit to struggling with the reasoning and physics behind the latter, though I'm not looking to start a fight or offer an opinion on something I haven't heard "first ear". I'm not even sure I could find the time to experiment with these speakers even if I found the motivation to do so.
The SMGa speakers are one of the best pieces of equipment I have ever heard, and certainly the best speakers I have owned and it is lucky that they suit the acoustics of our living room very well. I'm a total convert to box free speakers now. Recently I re-foamed & repaired some Infinity Kappa 7 3-way speakers owned by my father in law, and had a chance to compare them to the Maggies in the same room - the boxes were much less enjoyable.
If there were any comparison I'd like to make it would be against an open baffle design constructed from conventional cone speakers. The Maggies are oft touted as a harsh load, but they are largely resistive, and compared to "conventional" speakers, the weak "motor" doesn't provide much back e.m.f. to the amplifier, minimising that interaction. Furthermore, the distributed planar drive should mean that voicecoil heating problems and subsequent resistance variations are minimised. I guess this could (should) be the subject of another thread....
Ed
All comments about flat panels are just fine here Ed. We do not worry about off topic in EnABL threads, just like in the beyond the Ariel thread, all is grist eventually.
I agree about the mental concussion you get from trying to understand how something that those "who know" can only accept as mass loading of a diaphragm, can possibly migrate to hard, incidental, surfaces. No worries, it will all come clear some day.
In the mean time, the description I gave in the listening thread of the 2.6R Maggies of Rene' Jaeger, has been read and seconded by him. His actual comment recently was "no, I haven't torn the damn patches off, I am not going to, the speakers have disappeared" "I am not certain that it wasn't all just down to us having moved the maggies either... except, they didn't do this the last time they were there"
His wife is very happy, as there is now center channel for movie voices and extremely deep bass, and again, these could all be due to placement, since that is of paramount importance with all OB speakers and horns and anything else too for that matter.
To treat your side panels with invisible tape would take about an hour, cost about $4, and is easily removed. Then you would know if the patches were staying on or not.
Google Rene' to find out who he is.
Bud
G'day Ed,
Forgive me for not finding an image that was suitably dressed.
It was late and this was the only image I could find. :eek:
"First ear" experience is nothing short of a revelation.
Doesn't make things easier for the logically minded though...
Thankyou for the description of your speakers.
Based on that, I will post a drawing and description of an EnABL application I would use.
Alex
G'day Ed,
OK here is a 'proof of concept' EnABL treatment that is fully reversible.
Refer to the attached pic for the pattern.
No. of blocks: 76
Block size: 1" x 0.5"
Block materials: Clear contact (in case you like what you hear and wish to leave it in place).
Alternatively, 1/2" masking tape or even electrical tape.
1. Apply the pattern from top to bottom
2. Do ONE speaker only, then listen in stereo
3. Usually, the speakers will sound strangely unbalanced - this is the EnABL pattern at work.
4. EnABL the other speaker and listen in stereo.
5. The balance will be restored, but the overall sound will be different :cool:
Questions, comments?
Alex
G'day,
Here is a more advanced treatment for those willing to take their socks off. :D
The attached pic shows the EnABL pattern to apply around the driver aperture and baffle for a standard SMGa (ie. without the additional side pieces used by Ed.)
The sock will need to be removed to apply the patterns, then put back on.
Ideally, apply the patterns to the backside of the speaker also.
Alex
Thanks, I'll think about it.
By the way, the pictures you posted are exactly what I have - no additional side pieces on my speakers, just the original wooden trim/re-enforcement. Sorry if there was some misunderstanding.
I would say it will be hard to hear the unbalanced effect you describe. Since the speakers have quite a distinct sweet spot (tall, & large area high frequency source radiation characteristic) There are subtle changes based on speaker placement. Much of my listening is quite removed from the typical listener/2 speaker triangle, but these will speakers fill the room with natural sounding music even if ones ears are not positioned perfectly for stereo.
G'day Ed.
I did misunderstand your set-up - mind you, I should have clarified with you rather than assuming.
In any case, the simple application I proposed still applies.
IMO, folks using ESL, Maggies and 'single driver' style speakers are usually best placed to hear the changes EnABL brings.
Familiarity with the sound of your own set-up is more important than the absolute speaker/listener positioning when it comes to hearing any changes.
Only one way to find out really...:)
Alex
