wuffwaff said:Hi,
I don´t think you may use that formula to calculate ESR.
Your PSU looks nice but how did you make a 9mH / 0,2 Ohm choke?
9mH seems a bit overdone, normally 2-3mH is OK.
William
seems that I must look for some datas for ESR....
chokes are from old cinema projector PSU for sound bulbs (lamps)
EI 72 iron, n original PSU worked at 5A
I have exactly two-perfectly adequate for 4A for Babbelfish J
choky said:I presume that
1/(2xPi x 2x50Hz x C)
is best case?
anyway-look:
At power supply frequency that would be the Capacitive Impedance, Xc, in series with the cap's ESR.
sounds logical
- 'lytic and PSUd question
