I'm building a long tailed pair phase inverter and am wondering what the best thing to do with the second grid is. In others' designs I have seen it connected to ground via a small resistance (10k) or a large one (1Meg). Some even bypass with a capacitor.
What's better, a big or a small resistance? What benefit would bypassing give?
It depends on the DC voltage at the first grid. When the first grid is at DC ground, the other grid is generally either grounded directly or used as a feedback point. When the first grid is at an elevated DC potential, the grids are usually connected together with a large-ish resistor (which causes them to assume the same potential), then the second grid is bypassed to ground at AC.
rdf said:Every now and then I also see it AC coupled to the midpoint of the LTP plates with equal, high value resistors. Haven't seen a theoretical analysis of it though.
It's treated in Landee, if you have access to a copy.
You mean like Williamson?Why not a cathodyne in front of the LTP ?
Yeep,
yes, I made a google search and found this one.
Kind regards,
Darius
- Tubes / Valves
- LTP second grid
