LP 12 and Mark Kelly's Board
I used two batteries only because i could not fit a 12V 7.2AH comfortably in my chassis. I wired two 6 volts in series to get 12V. If you don't have a space restriction get a 12 volt 7.2AH SLA as it will be cheaper than the 6 volt equivalents. The 7.2 means how many amps the cells will put out over an hour. Since the battery controller draws less than an amp the battery will power the turntable for +-7 hours between charges. I used a Panasonic but any standard one will do. Try:
www.batterwholesale.com or another online dealer. They usually run in the $16 to $20 range
