Just recalled from memory visual wrong.
Here in DIYaudio --- solid state section is a buffer which might have potential --
http://www.diyaudio.com/forums/solid-state/240239-ultra-low-distortion-hp-buffer.html
But that LME should still be around in surplus as it isnt long gone.
-RNM
-RNM
It doesn't show on the simulation but M8 drives an active shield around the high impedance output of the VAS. It also drives C6 as part of the stabilization network. I'm not sure now whats on the PCB. I may have used a gimmick https://www.youtube.com/watch?v=v1wWL6TGWOE . The sim is a mod on the original that had 20 dB of gain and a larger feedback cap there. The sim works with a pretty small error on the RIAA curve. I'm not sure I would make a phono preamp this way today. The FET buffered opamp may be a better choice. It would address the level dependent input cap on the opamp, which is the dominant remaining distortion source, probably for all of this stuff. And I would be tempted to use DSP and correct for the actual response of the phono cartridge.
Nice trick. I can use this for vari cap trim.
30 AWG wirewrap wire works very nicely.
-RNM
Is that simulated distortion. Kind of hard to measure that low unless the noise gain was raised to 101 or so.
The LME failed.
Its simulated since there is almost no way to measure such low distortion. Simulations really break down when looking at ultra low distortion. Even the resistors would need more involved models. I don't invest a lot into distortion from simulators, just build the thing and see what happens with real parts.
Yes, an inch of wire in the wrong place can ruin the performance. At <-130dB no two realizations of the same circuit are going to match. It would be embarrassing to say how many times the output stage and the offset null circuit sharing current inadvertently on an IC op-amp caused a need for a mask rev.
That is an expensive oversight and probably very simulation resistant. Expensively acquired knowledge.
Now we have parasitic extraction, in the old days it had to be caught at a layout review and hand tracing of current paths.
It may turn out that a hand built amp/buffer will need to be made. I spent a lot of money and time on that HPA to get the THD so low. I liked the results so much I made another using same pcb layout. I didnt do the due diligence which I did on the first one and ended up with slightly below -100db. Still fine for HPA.
However, I could not do it to extreamly low levels without the best test equipment available. When I get the gen from David, I am going to use the first HPA with it. Part of the problem for me was the low-ish feedback amount. Should be less critical to do if slightly redesigned. Maybe as a buffer only? But still individual tweaking with best analyzer to get it to nill thd. Not a project for the DIY'er with simulation alone.
What levels of thd/harmonics was produced with LME type? How far off was it?
Buffer contender. http://www.diyaudio.com/forums/solid-state/240239-ultra-low-distortion-hp-buffer.html
THx-RNMarsh
View attachment 576611 Buffer contender. http://www.diyaudio.com/forums/solid-state/240239-ultra-low-distortion-hp-buffer.html
THx-RNMarsh
Was that ever built, or just simulated? I am not sure I'd trust those numbers if simulated...
Was WHAT ever built? BUffer? I dont know. But have to start with something and see.
Or this one is ultra low thd ----
View attachment schem.pdf
-RNM
-RNM
http://www.diyaudio.com/forums/equi...on-audio-range-oscillator-55.html#post3497666
I know it was from a long time ago, but has this ever been built ?
Such elegant circuit, would be a shame not to ......
Patrick
Thank you. Really the shame
Today I made this prototype by modifying my serial generator's schematic.
Here are the spectrums measured via passive twin T (the scale is properly adjusted at 3kHz):
traditional schematic - http://content32-foto.inbox.lv/albums/e/elterra/TwinWienB/TrWienB.jpg
twin Wien bridge modification (same board, same opamp) - http://content32-foto.inbox.lv/albums/e/elterra/TwinWienB/TwinWienB.jpg
system noise (input short) - http://content32-foto.inbox.lv/albums/e/elterra/TwinWienB/SysN.jpg
As we can see, the main difference is the lower noise. This modified schematic may has good potential...
Victor.
Victor.
WoW
-RNM
Victor- Which software are you using? I don't recognize it.
I am still using Spectrum Lab ver. 2.4.0.31
Hi Vicnic,
Here is release 2.7 for Spectrum Lab: Spectrum Lab 2.7 Download (Free) - SpecLab.exe
-Chris
-Chris
Hi Vicnic,
-Chris
Hi Chris.
Thank you .
"https://www.youtube.com/watch?v=v1wWL6TGWOE ."
Demian I tried this yesterday using some 30 AWG wire wrap. It works marvelously.
I did it a bit differently. Rather than twisting the wires I folded the wire in half then rapped a coil around the other end of the folded wire. Soldered in place and cut the shorting loop at the end. I wanted a trim cap. To tune it just cut some of the coil off the end. For fine tuning slide the inner strait piece of wire out of the coil.
I suppose one could fix it with a bit of glue but once soldered in, it will stay in place.
Total cost 0.006 dollars and a bit of labor.
I read somewhere it could take up to an entire year to get approval then.
The circuit I used in the NuForce preamp is pretty close. This gives the basic idea. I can send you the complete simulation. Adding the bipolar pair will have higher voltage gain at the input. The low noise pair from Linear Systems worked fine in the NuForce with very low distortion.
I can send you the complete simulation but its a pain to get the transistors into the database. I may have some assembled boards around here as well. It uses more real estate and has more output drive than the Shibasoku.
What's the noise like with this?
- Design & Build
- Equipment & Tools
- Low-distortion Audio-range Oscillator
