If you are going DSP, give the Harsch XO a try. See how you like it vs LR24.
https://www.diyaudio.com/community/threads/s-harsch-xo.277691/
Benefits are better percussion and snap on drums and string instruments.
Yes, the WG300 waveguide on my PTT6.5 TL speaker gives enough time delay that I can use a passive Harsch XO for time aligned speaker.
https://www.diyaudio.com/community/...using-ptt6-5-and-rs28f-in-a-waveguide.354778/
XO schematic:
XO curve:
Step Response:
XO schematic:
XO curve:
Step Response:
I have not read all this thread, but I thought this data might be helpful for you.
This is the PMC AML1 line. Ignore the decimal places, it is probably only accurate to the centimetre. Width of the line is about 165mm. I have some photos somewhere, let me know if wanted.
Somebody also measured the woofer T/S online. I dunno how reliable the data is but this is what they reported.
PMC AML1 Woofer t/s:
Fs: 62,48 Hz
Re: 4.00 ohm (dc)
Le: 0.182 mH
Le2: 0.890 mH
Qt: 0.43
Qes: 0.50
Qms: 2.93
Mms: 36.25 g
Rms: 4.864265 kg/s
Cms: 0.000179 m/N
Vas: 4.43 l
Sd: 132.73 cm²
BL: 10.666486 Tm
Lp(2,83V/1m): 88.29 dB
Fs: 62,48 Hz
Re: 4.00 ohm (dc)
Le: 0.182 mH
Le2: 0.890 mH
Qt: 0.43
Qes: 0.50
Qms: 2.93
Mms: 36.25 g
Rms: 4.864265 kg/s
Cms: 0.000179 m/N
Vas: 4.43 l
Sd: 132.73 cm²
BL: 10.666486 Tm
NIce,I have not read all this thread, but I thought this data might be helpful for you.
Fs: 62,48 Hz
Re: 4.00 ohm (dc)
Le: 0.182 mH
Le2: 0.890 mH
Qt: 0.43
Qes: 0.50
Qms: 2.93
Mms: 36.25 g
Rms: 4.864265 kg/s
Cms: 0.000179 m/N
Vas: 4.43 l
Sd: 132.73 cm²
BL: 10.666486 Tm
Please share more details and photos .
Thank you!
Greetings from Bulgaria!
I want to ask the author of the thread XRK971 if there is a change in the box of the original drawing at the beginning of the thread.
I will be using these speakers:
https://www.soundimports.eu/en/sb-a...XnnqPtGAynkTLXgTMR_6IbX7VCvhjOMHZMkaAtXbEALw_ w cB
https://www.soundimports.eu/en/sb-acoustics-sb19st-c000-4.html
This is the drawing I had in mind.
I see you used the same speaker but with the square chassis
![cop :cop: :cop:](https://files.diyaudio.com/forums/images/smilies/cop.gif)
Please post in English.
Привет от България!
Искам да попитам автора на темата XRK971 има ли промяна в кутията на оригиналния чертеж в началото на темата.
Ще използвам тези високоговорители:
Тази рисунка имах предвид.
Hello from Bulgaria!
I want to ask the author of the XRK971 theme if there is a change in the box of the original drawing at the beginning of the topic.
I'll use these speakers:
This drawing I meant.
@xrk971 - I have moved my speakers to a different room now, so thought of revisiting the measurement of the TL with RS180-8/DC28F version of mine.This is what I get, I had measured at 1m at middle point between woofer and tweeter.
Getting a huge dip around 40hz due to which the low ends are getting cancelled, seems a room issue any suggestions to fix it?
This is the crossover I did it for them now
Measured response in room
- Low-Cost PMC-inspired TL Monitor with DC130A and DC28F
