Looking to build....
If (as Tom indicated) the Klipsch RB-81s are 97 dB. efficient, Paul Joppa's 102 dB. rule tells us that (SIC) 4 WPC are enough. Deep Class "A" triode wired EL34s will affordably yield more than 4 WPC.
As a preamp (presumably with gain) will be available, the 12AT7 based "El Cheapo" splitter/driver is quite adequate. A 12AT7 and 2X EL34s comprise the signal tube complement of each channel (6 tubes total). Invest in decent O/P "iron". The Edcor model CXPP60-8-4.2K is the lowest grade item I'd entertain.
Hi...
If we're talking 30-60, I'm seriously interested,too!
Problem is, which of the many(?) alternatives out there are the "better" one?
( Whithout going to the very extremes, that is....)
EDIT:
Maybe I should add, - since I live and work in one of the "far away" corners of this world, I haven't heard any of the possible alternatives, and most probably won't either....
Only my brothers Cary's and a McIntosh....oh- and a Lumley....
AuroraB said:
Hi...
EDIT:
Dude,
You're not the only Norwegian member here. The other nordic countries are also represented.
Ultra-linear mode PP AB1 EL34s are good for more than 30 WPC. Do you already own a preamp with gain? If so, the small signal circuitry I proposed to this thread's originator will work for you too. OTOH, if you are starting from the ground up, a Mullard style circuit employing 1/2 a 12AT7/ECC81, an ECC99, and 2X EL34s in each channel gives you the makings of a very nice "integrated" amp.
Sowter (England) winds nice O/P trafos. A merger of the characteristics of their model U065 and their model U082 is what the situation requires. You want the more massive "P" core and a 4 KOhm end to end primary impedance. Don't forget the UL taps.
Lundahl (Sweden) also winds good "iron". However, the 36% UL tap on their most suitable model does not sit well with me.
Eli Duttman said:
Dude,
I'm very much aware of that fact......only thing is, - thre seems to be roughly 1000 miles between them and me.......;)
And-I'm quite familiar with Lundahl irons......I have spoken to the man himself on a couple of occations. European iron is not my problem, I think. There are several german makers, too.
My problem ( if considered a problem) is that I have little or no time to design or tinker too much..... I just want to build something reasonably good, and being the old geezer ( 55..?) I am, I do like to build it myself. That's most certainly a large part of the fun........
55, geezer? You're a "baby". :D I wish my carcass was that young.
Are you based up near Narvik or Hammerfest?
You spend the money to buy parts. There's plenty of help here on the design front. ;)
audiowize said:
I think you are a stellar candidate for a 300B amp. For a more affordable project, triode strap a 6V6/EL84 instead. Eli's amp is also a good candidate, but with speakers that efficient, a single ended amp would be pleasant.
Klipsch speakers are efficient. However, they seem to do poorly with the modest damping factors available with no NFB SET amps. I suggested Class "A" triode wired PP EL34s, as both sufficient power and adequate damping would be available. A LITTLE loop NFB provides the necessary voice coil control.
I completely agree with you on that. I get a little spoiled with my Klipsch CF-4's. Their neo 12" woofs seem to sound best with a nice loose SET amp, but this is generally not the case. Of course, you could always implement the feedback on a single ended amp, but saying that might get me booted out of here!
What ? An american(?) with local Norgie knowledege??? :D
Quite right---I'm about 200 km straight line NW of Narvik - on the tip of an island in the Norse Sea ( 69.3 N-16.01 E)........and I quite like it here !
Lots of fresh air and natures own forces ( and trout ponds and lakes!)
As for the amp question... 300Bs and the likes are not for me , - not yet at least. My current speakers are around 89-90......
I play mostly classical, but the odd Cream or Zappa and the likes creeps up in between....;)
billbeau said:
Can anyone suggest a nice SE amp some NFB? Schematic with parts list.
50-60 watts. I would like to build a set of monoblocs. I am building a tube pre using two 12AX7s and one 12AU7.
Dude,
You may not realize it, but you are JESTING. :cannotbe: SE amps must be Class "A". The max theoretical efficiency for Class "A" is 50%. In the real world, less than 50% is what you get. For example, 20% efficiency is common, when triodes are employed.
If you want "55" WPC, use UL mode PP KT88s. :att'n:
A little bit back on topic...Getting 50 Watts or so in SE can be done by using transmitter tubes of various types & there is a bit of a fringe group that likens to this genre.
My idea was to build an SE with 45 WPC using the 813 tube. Rather a big tube using very high voltages. I've put it all together on paper but found out an output transformer would run appx. $750 each...
That has slowed down my progress.
High power SE designs are doable but way out there in practicality.
______________________________________Rick..........
40-50W SE will require some rather special and costly transformers, I think.. not what I want to do at this stage.
Even if the thread starter asked for 100Ws, I 'm still interested in what difference there are in different topologies.
I've asked this question before, but really didn't get any conclusive answers. I realize that this is apples and pears to some extent, but i was hoping for some pointers, at least....
These are the links I posted a couple of years ago:
http://www.vacuumstate.com/schematics/pp-1c_s.gif
http://www.pmillett.com/push-pull_k..._driver_pcb.htm
http://www.lundahl.se/claus_b.html
http://home.tele2.fr/boutailh-tan/ampli/ampli.htm
http://www.jogis-roehrenbude.de/Les...auanleitung.htm
Somehow I am leaning towards the last one ( which also have a appx 100w version). The output transformers seems to be of good quality, and are avaialble here:
http://www.roehrentechnik.de/html/gegentakt.html
Unfortunately, tha last ones are only available in german, but schematics are usually language independant,
( aren't they....? :cool: )
