Looking For Output Transistors For Vintage Car Radio
Hi again,
I'm searching for some output transistors pictured below for a few old Philco car radios. Can anyone steer me in the right direction where I can purchase these or similar that would be compatible?
The numbers on the face are:
AR-14
6522 1012
I told you I was new :)
Much thanks!
Steve
Hi.
The number is almost certainly an in-house number. I have not seen it before.
Is this transistor the same size as the other one you were asking about?
Is the radio +ve ground?
If the answer is yes to both, then OC35 / OC28 or USA equivalents will work.
Andy
