Looking for help identifying burned up part on Crate PA4 circuit board
Hi - I was playing an outdoor show near the water last weekend and was given a power line to use that was running 208 volts vs. 120. The organizers of the event had no clue what they were doing re: electricity. So it goes. I determined the voltage using a multimeter after the bass amp and the PA head died. Argh. The bass amp just needed a new fuse the but PA head burned something up.
It's only a cheap 4 channel Crate PA 4 but I like it cause it's through hole design vs. smt and should be fixable for a long time in situations like this.
So I took it apart and found the burned up part which was pretty easy as you can see by the pictures. I was planning on just reading what the part label was, comparing that to the schematic I have, firing up the soldering iron and fixing it myself.
But I've been foiled by the disappearance of the part label. I think the part melted the label when it burned up.
Could anyone help me figure out what part this is? See attached schematic and pic.
I was planning on replacing the two diodes immediately above the burned up part (D1, D12) as well just to be safe since the parts are cheap and it takes a while to disassemble / reassemble the thing.
Any other advice appreciated.
Thanks!
  • pa4.pdf
:) I looked at the pics and looked at the schematic, then used both process of elimination and "sure looks like it connects there." I only knew the transistor type by looking at the schematic, but that was a good clue since the other transistors in that section are in smaller packages.
And resistors don't burn up on their own, so if that resistor burnt up, something connected to it is also bad. Most likely a semiconductor.
Along with the power amp schematic, I have included the parts layout with parts list.
  • 48102B0_.pdf
  • 48102C0_.pdf
Brilliant - thanks for those files, Enzo! They confirm that the part that's burned up is R16.
Question for you - did you read the explanation at the beginning about the problem with the power supply we plugged in to? I was hoping that would explain why the resistor burnt up.
thanks again,
dave
Yes, I read the entire thread.
That may have been the underlying reason the system failed, but in a repair situation we also must look at the failure itself. Faulty power may have caused such and such a transistor to fail, which in turn burnt up a resistor, or some similar sequence of events. But we are now looking at a resistor. If that resistor burnt up, something else allowed the excess current to flow through that resistor, and we need to find out what that is.
If a college kid gets drunk and falls off the roof, the emergency room may like to know that, but it doesn't really tell them which organs will need surgery.
There is no magic list of things that will fail when 208v is applied instead of 120 to the main plug
Hey there guys, I don't mean to hijack the thread but I'm having a problem with a friend's PA-4 that I need help on. I was playing a gig last weekend and I had a friend set up the PA before I arrived as I knew that I would be late. The DJ who was to begin spinning after I finished up decided not to plug the PA-4 into the Crate speakers I had supplied but instead into his own speakers (which look decidedly more intimidating). So I turn on the mixer head when I get there and there's not a spark of life to be seen. I'm presuming that the internal fuse is blown (we tried a few different power adaptors to no avail) so I've tried loosening the screws on the back of the console so I can see what's going on. One of the screws is being very stubborn and refuses to budge but I'd like to know if I can actually access the electronics by taking off the back plate before I get tough with the screw. Thanks in advance (I know very little about electronics so I might need more help before the thread is through!)
