Hi, I didn't know where to put this, so sorry if it's in the wrong section.
I've been curious to know, is there such a surround processor that can take 2-ch input from a 600w/ch amp @ 4-ohms and distribute the power amongst 2x110w (front), 2x100w (rear), and a center channel?
(I also need one with line-level output for a powered sub.)
As an alternative, would it be practical to re-route the circuitry on such a processor to bypass the internal amp and pass through mine instead?
Thanks,
Brian
Thanks,
Brian
Hi Brian,
You may not have gotten any answers yet because you question is rather confusing.
What do you want to do?
You want to have left-center-right + 2 rear?
Normally that is done at line level in a processor of some sort. Generaly built into AV receivers these days.
Then you will need 5 channels of amplification. Again, built into receivers. But you can use a separate processor and separate power amps if you like. Just remember that the processor is upstream of the power amps.
Yeah, I see how impractical and confusing the question was now. At the time of writing I really had no idea of what sorts of equipment were available on the market, or in what order the average A/V receiver handled the signal from start to finish.
I was hoping to find a standalone processor (with absolutely no other functions) that assumed the amplification had already been done, but from what I hear such a thing is really not cost-effective on the consumer level, or common to find anyway.
I'd be glad if a mod can delete this thread. Thanks.
- Brian
- Brian
actually...
Actually, what you're looking for certainly exists, and only fell out of popularity due to surround receivers becoming mainstream.
It's a passive high-level (post amplifier) surround decoder circuit, based on the Hafler circuit back in the 60's and 70's...
Here's a schematic and some data:
http://sound.westhost.com/project18.htm
http://www.pmb.co.nz/hobbycorner/pages/pro_hif0.htm
http://www.sonicdesign.se/matrix.htm
and as an actual implemented box here:
http://cgi.ebay.com/DYNACO-QD-1-SUR...ryZ14978QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I actually purchased one (a later model QD-1) that has much nicer binding posts for use in my home setup. It worked very well, and I later retired it due to purchasing an actual Dolby Digital/Pro-Logic receiver.
If you have a high-power stereo amplifier, this circuit will definitely work. The only important thing, is to try to have matched speakers all round...
If you're interested in the unit, I can sell it to you for $20 and $10 shipping (it's actually pretty heavy)... if so, email me at:
taloyd AT gmail DOT com
hope this helps,
-tal
hope this helps,
-tal
Wow! Thanks for that reply, I've been told everywhere else that either no such thing can be purchased by itself, or I'll never find one at a worthwhile price.
At this point, I'm looking at full-on receivers, but for the time I may just buy one of those until I can better afford a high-end receiver.
I'm going to visit family for a few days, but I might just drop you a line when I get back.
Thanks again!
- Brian
Thanks again!
- Brian
That box looks like a clean solution. But, if you want to try out the Hafler circuit (or part of it), you can wire up a simple Hafler circuit with just speaker wires (assuming that your amp can handle low ohms, but then, that's probably still and issue with that box -- I'd be afraid to do this circuit on a typical receiver).
I just connected 3 speakers (L/C/R) to a beefy 2ch amp. I'm still trying to decide what to make of it. Instead of having a distinct separation, it kinda blurs the channels together, creating a more seamless presentation. But it definitely gives you sound which images convincingly. Interesting.
Caution: if you wire this yourself, you need to not only take care to wire it correctly, but if your amp does not have a common-ground, I'm pretty sure that the wiring is different than if it does have common-ground. So, that's something to watch out for when looking at these diagrams.
Prolly the reason it's so hard to find information on stuff like this is that you can basically do it for free. I don't mind promoting it and sharing the fun, though.
Panomaniac: Just to let you know I emailed taloyd about the box he's got, but good luck getting one for yourself. They do seem quite worthwhile.
My amp is definately beefy enough - it can handle 2-16ohms, and even distributes unused power "intelligently" to make better use of its capacity for high wattage.
Thanks for the tips.
Vidgamer said:That box looks like a clean solution. But, if you want to try out the Hafler circuit (or part of it), you can wire up a simple Hafler circuit with just speaker wires (assuming that your amp can handle low ohms, but then, that's probably still and issue with that box -- I'd be afraid to do this circuit on a typical receiver).
That's the main reason I've been looking around for a commercially available product. My hopes are such a box might preserve imaging better then a simple wiring job.Originally posted by Vidgamer I just connected 3 speakers (L/C/R) to a beefy 2ch amp. I'm still trying to decide what to make of it. Instead of having a distinct separation, it kinda blurs the channels together, creating a more seamless presentation. But it definitely gives you sound which images convincingly. Interesting.
bezeek said:...
I dunno, I'm enjoying this 3-speaker setup!It has better imaging than I expected. I mean, you kinda think that it must be a blurry mess, but it really isn't.
- General Interest
- Everything Else
- Looking for a surround processor.
