Looking for 10,000+uF / 80-100V caps
Since six of my eight Nippon KMH caps in my P101 amp have failed I'm left without much filtering on the supply...
So I'm looking for 8 snap-in caps to replace them, 10,000 to 15,000uF at 80-100 volts (I prefer the latter).
Maximum size is 35mm diam. X 85mm height, must be good (known) brand, not used before and the newer the better.
Of lower importance - I'm also looking for lower voltage caps, around 10,000uF/50-63V for another project.
Thanks.
I think these babes would never die on you :)
Just look at the terminals... You can't pass that much current through these 0GA solid aluminum posts, so you could kill the cap, can you? :D
