LME49830 like driver chip for Quasi-Complimentary?
I want to experiment with silicon carbide static induction transistors (SiliconSouth SJEP120R063A), but they're only available in the N-channel sex. Use of a transformer is out cause I'm targeting 110V rails and want direct coupled.
Could a build-out circuit on the LME49830 be made on the Pout pin for swapping polarity to make it work?
Topology-wise it can't this simple as adding Q4, is it? MOSFETs being used in place of a pair of SiTs
/curses customized Google searches
I was able to find plenty of references to the Shaw and Baxandall articles, but that's it.
Anyway, I've had some fun simulating a quasicomp stage (BC637/638, 4x BD137F, 2x 20V), and it's been an interesting experience so far. Looks like a negative DC offset increases CFP output quiescent current, and if that makes your amplifier unstable into critical capacitive loads, you're in trouble. Yet, with a sine signal crossing the same regions, the simulated circuit never breaks into oscillation. Huh?
I'm worried about the same stuff. below +/-50V it seems stable. Above 50V, not so much. At least that's what the sims say. I'll probably have to run the gate resistor to a more negative rail to make sure it can turn off.
I might just do the smart thing and forget class-a/b chip amp and just go discrete with a circuit intended for quasi.
