LM4780 Single side PCB
Cast thee out jumpers! Though now it has to change anyway...
Many thanks to Upupa (and all the others of cource) for helping me.
Still having some questions:
1. Capacitor C3 must be closer to LM4780 or it's ok?
2. Input capacitor (1u) must be MKT or better MKP?
3. Is VISHAY SFERNICE RPL3 a good choise for the output resistors?
4. Are lines Vee, Ground and Vcc lines to close one another?
Retired diyAudio Moderator
Joined 2002
bill1961 said:
You mean something like this:
How about something like this?
Also, if you use the smaller resistors (5mm spacing, 3.2mm body length, 0.5w), you can make the feedback paths shorter and the board smaller.
EDIT: looks like you beat me to it, as I was referring to the earlier design..
Brian
