Lm3886t
Just biult a pair of these lasr Saturday. Point to point took about 3 hours. Works great!!! The schematic is right out of BrianGT's manual.
Note: I did not use the Zobel network or
Coupling/input caps aren't necessiary for these circuits in my experience. If you want to add one in, be sure to make it pretty high quality since it can make a substantial impact on the sound of the amp.
It makes sense to me that R1 and R2 are there to set up an input voltage divider. R1+Rin makes the first stage, but on looking at it again, it is a little wierd. . .
Oh yea, back on topic, in addition to the gainclone-esque circuits, I like the Linkwitz LM3886 implementation(attached). I am powering mine with +/-30V rails with 4,400uf per rail using a dual mono unregulated PSU. This is probably a little overkill, and the amps definitely work with 2,200uf/rail/chip, but I had a surplus of 2,200uf caps laying around, and one thing led to another. . . :D
Determination of whether the input coupling (DC blocking) cap is needed depends on the DC offset (or lack thereof) from the prior stage.
Prior stage is commonly the source, or a buffer/pre/etc. Many have coupling caps on their outputs already, in which case another coupling cap on the power amp stage input is redundant. Some (especially DIY), "might" not have that output coupler cap, so before one goes amplifying the signal to power amp levels it is important to measure for the DC offset (L to Gnd, and R to Gnd) if there is any uncertainty.
The circuit shown is with the variable pot for volume control. The way the circuit is usually shown (the base model) is without the pot.
I believe that without the pot, resistors R1 and R2 would be needed, the pot does seem to make them superfluous.
That's why they show up in this circuit though, it's the original circuit with a pot slapped on the input stage.
