shouldn't be any significant audio frequency current in the RC Zobel leg, and it should be totally linear so even if Zobel current common impedance couples with a signal ground it should only give a small frequency response error
the RC should be close to the chip - the series L closer to the binding posts and if open/solenoid should be kept away from metal, especially ferromagnetic casework or hardware
- Chip Amps
- lm3886, advice before soldering
