LM2670 in digital power supply
LM2670
Hi Stephan,
The closest one to the '2670 I have worked with is the LM2677. Same as your 2670, but with a 5A rating. You might think of upgrading to the '2677 when replacing. What package is it? TO-220? Sutrface-mount? I have worked with the surface mount versions before without too much difficulty. You just need a steady hand with the soldering iron. :D
What was the failure mode of your '2670? Open? Short? Did it take any other components with it?
HTH,
Steve
Hi Steve,
what I haven't understood, is the output capacitor, in the spec are very specific selection criteria.
Makes it sense to choose a greater value there?
Stephan
