I was bored, so I opened mine up...
Remove the tubes.
Remove the four screws that hold on the front panel.
Remove the four screws that hold on the back panel.
Lift off the bottom cover.
Remove the four screws that hold in the PCB.
Remove the four screws on the top cover that hold the heat sinks for the output transistors.
The PCB can be lifted out.
Mine is a little Dot 1+ and the pcb is marked as v2.0
Terry
Remove the tubes.
Terry
