Listening Test Part 2. Active Circuitry.
Administrator
Joined 2007
This is the second of two listening tests and is for active powered circuitry, the other thread is HERE and is for passives.
PLEASE READ THE OTHER THREAD AS THAT GIVES FULL INSTRUCTIONS ON HOW THE TEST WORKS.
The links to the files are at the end of this post.
What is this test about ?
This test is between two different opamps, an LM4562 and an FET TLE2072. For those of you that have seen and taken part in previous tests I can assure you that the equipment used here is NOT the Sony CDP790 but a Philips based DAC using twin TDA1540 convertors and with supplies of -/+12 volts for the analogue stages.
Your results.
Please read the other thread for full instructions and mark your results "OPAMPS" for this test.
And above all, ENJOY :D
Links,
https://www.dropbox.com/s/432julrqkma68zi/X.wav
https://www.dropbox.com/s/ifq22qdb0kf3wfm/Y.wav
https://www.dropbox.com/s/c313uad5yyfk84x/Test_01.wav
https://www.dropbox.com/s/ogpiv79nreu07bc/Test_02.wav
https://www.dropbox.com/s/sbe0pg6g09i3ogy/Test_03.wav
https://www.dropbox.com/s/zx1yv8ppc3s0xlk/Test_04.wav
https://www.dropbox.com/s/gs6az861wdaz2j2/Test_05.wav
https://www.dropbox.com/s/4ab15xffc42yoss/Test_06.wav
https://www.dropbox.com/s/5k7z33gvtk0nruo/Test_07.wav
https://www.dropbox.com/s/21vzdn3esi1l0v9/Test_08.wav
https://www.dropbox.com/s/lfq7l0se6qpz6zy/Test_09.wav
https://www.dropbox.com/s/sv920vdpqd6cev8/Test_10.wav
https://www.dropbox.com/s/5l9euwavcbf90tn/Test_11.wav
https://www.dropbox.com/s/4rbjx7oahkl30jp/Test_12.wav
Just downloaded and had a bit of a listen to X and Y ... for me, these two versions are much closer than the Passives reference tracks, the clues, cues are quite a bit more subtle. Yes, I hear a difference - but the sorting of the samples into 2 bins will require considerably more focus, I suspect ...
Administrator
Joined 2007
Interesting that you find these a tougher test. Out of the passives and actives, this was the one where I felt differences would be most apparent, particularly after experience of the other opamp tests. The TLE2072 seems an oddball chip (which it shouldn't be) and I didn't want to dismiss it out of hand despite the previous tests.
As before... thanks :) You are one of the few to be approaching these tests in the true spirit they were offered... which is to give them a listen.
Thanks for the clarification :)
So are these chips operating as I/V converters for the TDA1540 or are they line stages after another chip (inside the CD player presumably) has done that function? Just curious to know how much ultrasonic stuff they're being subjected to here.
Administrator
Joined 2007
Pretty much identical to this. Yes I/V conversion and the usual anti aliasing filter arrangement
Administrator
Joined 2007
Thanks Mooly - unless I'm kidding myself that looks to be something very similar to a Philips CD104 player with SAA7030 4X oversampling digital filter.
Classic model indeed :D
Yes the picture is actually of a CD303, and the one in the test is a CD150 with virtually identical signal processing circuitry. All these Philips players were pretty similar electrically I seem to recall.
Administrator
Joined 2007
Well interest in this one was lacking unfortunately with only one complete set of results submitted (thanks again Frank), so with that in mind here is the key and the result.
Participant. File. Actual. Match choice Result. (Yes for correct, no for incorrect)
fas42 Test01 TLE2072 X Yes
fas42 Test02 LM4562 Y Yes
fas42 Test03 TLE2072 Y No
fas42 Test04 TLE2072 X Yes
fas42 Test05 TLE2072 X Yes
fas42 Test06 TLE2072 Y No
fas42 Test07 LM4562 Y Yes
fas42 Test08 LM4562 Y Yes
fas42 Test09 LM4562 X No
fas42 Test10 TLE2072 X Yes
fas42 Test11 TLE2072 Y No
fas42 Test12 LM4562 X No
Copy and paste of key.
Test_01 = TLE2072
Test_02 = LM4562
Test_03 = TLE2072
Test_04 = TLE2072
Test_05 = TLE2072
Test_06 = TLE2072
Test_07 = LM4562
Test_08 = LM4562
Test_09 = LM4562
Test_10 = TLE2072
Test_11 = TLE2072
Test_12 = LM4562
Standard reference files.
X = TLE2072
Y = LM4562
Copy and paste of your results:
X: 1, 4, 5, 9, 10, 12
Y: 2, 3, 6, 7, 8, 11
Consistent with the number right, at least, :D.
Jay felt he had no trouble distinguishing the 2, shame he didn't submit a try. Overall, my feeling is that inconsistencies in the state of the electronics between takes, and the characteristics I focus on to separate the samples don't tie in with what is being tested for, hence the meaningless outcomes. Electronics varying in their subjective capabilities from one time to the next is what I've been 'battling' with for years now, so I'm not at all surprised, in retrospect.
The cap1, cap2, cap3 test is a classic example of where nominally the same hardware produces different results, at the subjective level - and no clear reason why ...
