Ebaybid
Hi Eric,
So it was you who won the bidding on the HPscope with the faulty brightness adjustment or is this a other one?.
The big problem with Ebay is you have to believe the seller. The device may have hidden faults even the seller does not know of.
Personally I don't like to buy a defective instrument though repair shouldn't be too difficult if a schematic or servicemanual is available. I own a TEKtronix 321A. It is a lovely cute beauty though very limited in bandwith. Still looking for a 200MHz+ one on the cheap, for the clock circuits you know.
Hi Eric,
1707b bandwidth
Capslock: the bandwidth as specified by HP for the 1707b is 75mhz. However, the e-bay seller can "fudge" that to a certain extent, as even a 75mhz 'scope will still display and even trigger to likely past 100mhz.
An honest seller would have advertised it at 75mhz, though.
Thingyness,
thanks a lot!!! Do you have a spec list or can you just tell because there is some system to the type numbers?
Swede,
I don't know how big the market for used scopes is in Sweden. Here, the 465 sell for around 150-200 Euro (466 and 475 sometimes also). There are some guys around who buy up surplus and test the things before auctioning them. I had bad luck because the guy who sold me mine simply copied the discription from somebody else.
On www.ebay.de there is currently an offer for a 485 (350 MHz) in full working order for 300 Euro. Auction ends about 24 h from now. Auction number is 1346363670. You can also search for Tek* 485.
I would probably build a signal generator rather than buy it.
Greetings,
Eric
Swede,
Greetings,
Eric
capslock:
I can tell because I did a search for "hp 1707b scope" on www.google.com
For all of you who are looking for good cheap test equipment that is KNOWN to be working, check out Tom Gootee's page:
http://www.fullnet.com/u/tomg/gooteesu.htm
He has tons of excellent 'scopes and is often cheaper than eBay, but he guarantees his stuff works!
- Design & Build
- Equipment & Tools
- list of heritage oscillospcopes with specs
