The new Decware ZDAC-1 for the under a grand category.
Audiophile Tube Amps and Tube Gear from DECWARE
I'm sorry Dave but this Decware DAC is a complete rip off. look at this thread page, post #2906:
http://www.diyaudio.com/forums/digital-line-level/137976-experience-diy-dac-291.html
The DAC that Decware uses is this chinese DAC from ebay:
Gigawork 24/192 Up-sampling DAC DA CONVERTER w/ USB kit on eBay (end time 26-Aug-10 09:00:30 BST)
Shocking really. Just buy the ebay kit and save hundreds of dollars. The ebay DAC is actually very good.
Thread link for the grubDAC (disclaimer, it is my design):
The GrubDAC - Head-Fi: Covering Headphones, Earphones and Portable Audio
Thread link for the BantamDAC:
Comments for my PCM2702 DAC layout? - Head-Fi: Covering Headphones, Earphones and Portable Audio
Such a very amazing link!
Thanks you for the post.
Dolby Digital A/V receivers are officially obsolete thanks to HDMI. I've seen a couple under $50 at thrift shops and pawnbrokers. Some have preamp outs.
Dolby Digital add-on processors like the Technics SH-AC300 and 500D. While there were similar boxes from other brands, I believe the Technics SH-AC500D sold in much higher numbers because it was the only processor under $1000 to do DTS as well as DD. And it made a perfectly usable standalone processor when combined with separate power amps.
There were or are some DD processors made for autosound and as add-ons to computer speakers. Not common, and overpriced on eBay, but you may stumble upon one locally. I picked up two car DD/DTS processors for $25 each on a clearance table at a car stereo shop.
And, finally, digital recorders like Minidisc, DCC, DAT or CDR should have digital inputs and therefore could function as DACs.
The Behringer SRC2496 can be bought new for under $250, not $450.
And USB devices should include the ADSTech "Instant Music" which used the same chip as the Behringer UCA202 but achieved better performance (according to someone's RMAA loopback test). ADC, DAC, Toslink in and out
http://www.adstechnologies.com/index.php?main_page=product_info&cPath=3&products_id=10
Sorry I haven't kept up with this. I'll look through some posts when I get a chance.
I moved the list to a Google Spreadsheet. If you'd like to collaborate, message me. There are still holes. I especially need help with cost estimates for DIY DACs.
I also added lots of expensive DACs for some technical comparison.
List of DACs "Under $450"
Nice list. DACs have gotten so cheap I am contemplating just buying one vs DIY. Just finished a Hypex amplifier. My old preamp is broken. So I am mainlining an old Sony ES CD player into the Hypex as the Sony has a adjustable,via remote, variable output.
I am thinking about the Matrix-mini or the Emotiva, as I would like to have balanced out and also, for the short term, a volume control. Tho I think the digital volume controls are crappy due to lost bits.
Great list of DAC info.
I'm using a PopPulse PCM1796 MKII that I found on ebay for $185. Wow, what a great buy; quality construction and amazing sound. The unit is compartmentalized to separate power transformer from the DAC circuitry.
Here's a link to the photos and specs: Pop Pulse - Product - Pop Pulse - PCM1796 DAC MKII
I did not see any mention of e-bay specials out of guess where? I have several. One was so bad I sent it back. (A Wolfson that had dropouts and noise) Another is clearly better than it's price and has a fair headphone amp in it too ( BB ). Needs a serious power supply upgrade and some tweaking on the analog, but a really good base for DIY.
AMB γ1 has CS8416 and WM8501 or WM8759, but γ2 has SRC4192 and WM8741, WM8742 or WM8740.
Looks nice, in particular y2.... I really like the layout / PCB design /ground planes
Well done.
Boky
amazing what you can get for $1000...
‰æ‘œ5 - ƒIƒ“ƒLƒˆ�[�A192kHz/32ƒrƒbƒg‘Ήž‚ÌUSB‘ΉžDAC�uDAC-1000�v‚ð”*”„ - Phile-web
Boky
Boky
Boky
The Onkyo 32-bit DAC is listed on e.Bay:
ONKYO DAC-1000 32bit/192kHz USB DAC DA Converter | eBay
But it is for Japan; runs on 100 VAC.
Fiio E17 Alpen ?
The FiiO E17 Alpen has been getting good reviews and might be worth a spot in this list. $150. Spdif (coax and optical) inputs and line out. Headphone amp. Very portable. Runs on batteries and probably on a "charger" as well for ac line duty.
http://www.fiio.com.cn/product/index.aspx?ID=41&MenuID=020301
http://www.fiio.com.cn/upfile/File/2012/20120107155431.pdf (scroll to the last page for chip complement)
So I've had the e17 for a little bit now and it seems pretty good so far. No hiss at 0 gain but there is some when you turn the gain up but that's to be expected. SQ is definitely better than what my macbook pro puts out through the headphone jack - the bass is much better and there's less noise.
It'll mainly be used for my playstation though, so the only music this thing is going to be reproducing is gunfire
outstanding.. for the asking price!
Boky
- Digital Line Level
- List of DACs Under $450
