I did.
I'm using 32 SB65WAC25s per side in my recent line arrays and they sound delightful. Based on how this thread started with discussion of really inexpensive TV drivers, I thought there would be little point in mentioning them. And the DMA45 is responsive to the specific question that was asked.
Full range line array for wall or corner placement
This Visaton Driver is at the top of the heap for 2” with the best off axis measurements I’ve seen as well as high efficiency for PA use.
Visaton FRS 5X-8 2" Full Range Speaker 8 Ohm
Note the rising response which will naturally combat the declining HF output from comb filtering consistent with vertical arrays.
- Full Range
- Line array using 1.5" to 2" max driver?
