Somebody knows of something capable to block a light beam depending on an electric signal?
It should block all the incoming light and be as fast as possible, but i would trade speed for ability to block light.
I can find a lot of patents online but not a "buy-able item".
Any idea?
EDIT: I think it should be something from the microelectromechanical bin, probably fiber-optic related.
Any idea?
Did you try Edmund Optics?
http://www.edmundoptics.com/
Tons of shutters, splitters, lenses, etc.
Like this one...
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2813
But, not too sure of your budget. Look around there, though.
Like this one...
croat47 said:Did you try Edmund Optics?
Like this one...
Thanks for your quick reply! I was looking for something that "turned black" or "turned transparent" when as a response to an applied voltage, but that did at 100KHz minimum (if i didn't need high speed i would use a calculator LCD screen). I belive that such a thing might be used in some optical fiber systems as an alternative to switching the LED or laser.
There are also "choppers" like this one:
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=2223
But, only 20kHz top end.
Wonder what the recovery time for a liquid crystal is and if that would even allow 100kHz?
What about this:
http://www.optronsystems.com/html/products_shutters.htm
What about this:
