apolon34 said:hi,
i have some problems with mine, which i'm building.
the schematic:
i have added a 56pF cap between base and collector of the pnp stage driver, which sold the problem, but only with no load connected.
when i add a 8 ohms load, it goes into oscillation.
do you have a solution ?
thanks
Have you tried putting small capacitors (from 47p to 1000p) across R2 and R3?
