Lang 20w Class A amplifier
In 1985 or so I built a pair of amplifiers from an article in Audio Amateur issue 2/85 called the Lang 20 Watt Class A Mosfet.
Does anyone have a copy of that article? It's spring cleaning and I want to sell these old amps, but I don't have the documentation.
Many thanks
Les
AX tech editor
Joined 2002
Many thanks
Les
Les I could scan it for you but it would have to wait until Monday or Tuesday when I get home again. Send me e mail if you still need it then to jan at linearaudio dot nl
jd
Completely off topic, i have a question for you, Jan..
I saw that you did mount a Nemesis amp.
The 2sk135 is not that much obsolete, and it s in fact still under
production under the 2sk1058 marking along with a modded case
that is now top3.
Now, the question : how does this amp sound ?..
would be curious to know about your listening experience
with such a design..
Many thanks
Les
I have found an ebay auction about this excellent book also inside the article from Lang, 20 Watt Class A (Item number: 380028710229 - I know this book). It is used, but very cheap.
