make it 1800VA per channel
Sacre bleu...! Mon Dieu....!!
thanks michael , i have just found that i 'v got big fanless cpu heatskink to try also they are rated 65W .. i will try this on the top of the TO3 with mica . i have seen the Pass had tried to swap the 10000uf CAp with a 1000uf MKP and get 30hz . do you think with 1800uf i could get 20hz?
I seriously doubt that a CPU heatsink is going to work well here. I don't recommend dinky heatsinks (fans or not). See my first post in this thread where it says "Don't skimp here". You've been warned.
This project is best built according to the author's specifications. That's why he invested the time and effort to write it; so you wouldn't have to learn too many things the hard way.
I provided you with a calulation, so you could find the low frequency cutoff and response with any capacitor you like.
sorry , i was lost , the wine perhaps... i have found a more suitable one on farnel :AAVID THERMALLOY - NV115-1
The ones I'm using now I hand-wound on cores/bobbins from Hammond 1628SE (now 1628SEA) transformers (about 11lbs each)... It's a quadfilar wound transformer with 16ga magnet wire, using 2 windings in parallel for the primary and secondary.
I've asked Edcor (today) about making some, but haven't received a response yet.
Roscoe
Roscoe
Have to finish up the F5 which is Dad's Christmas present as well...
A nice present.
Show us a pic of that transformer if you get the chance.
- L'Amp: A simple SIT Amp
