Elso and others...
I'm putting together a parts/order list given the list of items in the zip file.
I'm having great difficulty finding the Spectrol pot. Newark carries them, but they are out of stock and require a minimum of 200pc order. I have noticed that this pot has a very sensitive travel -> 25 turns... Is there another pot that others have used or can suggest that will be an adequate replacement since I can't find the darn thing anywhere?!?!?
2) I've been thinking about getting PPS Film or Polyester caps from Panasonic instead of the ceramic type as suggested. From my limited knowledge, I thought the film (and film/foil) caps were better high frequency performers than ceramic... comments? Recommendations?
thanks in advance...
Parts for KWAK-CLOCK
Hi Tieftoner,
For me it's difficult to give advice were to get parts as you live in the USA and I am at the other end of the big pond Europe.
To give you an idea which parts I am using:
The ferrite beads can be obtained from www.farnell.com Part# 323-4861.
The 2.2mH Neosid inductors are from www.conrad.de part# 535796.
If I recall right these are 21 Ohm DC resistance and rated for 105mA. As my clock only draws about 7mA this appears no problem. I believe www.mouser.com and www.digikey.com
have suitable inductors from other sources.
The pot I got also from Conrad but Farnell also sells it. Any other 2k pot also will do, as the adjustment is not critical at all.
I experimented a lot with other bypass caps like polyester, polypropylene etc. To my ears the difference was not audible. A little bit of improvement can be gained by placing a Oscon, 47 µF directly at the FET supply i.e. the Drain.
Hi Tieftoner,
Elso,
Thanks very much for the input!
I know that components can be extremely critical sometimes (as seen in the post comparing your clock to the Guido Tent XO2 clock). And I didn't want to risk changing something that might alter performance (at least for the worse).
To clarify, the pot doesn't have to be a multiturn? What exactly does the pot adjust so I know what to look for on my scope...? It appears to set the input level to the non-inverting input to 0. Why not just tie this input to ground? Should I be looking for a voltage value as close to 0 as possible at this pin, or should the non-inverting input be biased to one side of the supply?
One last question... should I go with metal film resistors to for lower noise and greater temp stability? Or are carbon film adequate?
KWAK-CLOCK parts
Hi Tieftoener,
The pot adjusts the duty cycle of the clock.
When adjusted correctly you should have about +1.4 to +1.6V DC at the wiper. It does not need to be a multiturn. I just like these Spectrol pots and they have a small footprint. I you connect the 50 Ohm coax with the 50 Ohm resistor at the scope end, you should adjust for the best possible symmetrical squarewave at the scope.
I am using 1% metalfilm resitors throughout. Maybe it also works with carbonfilm resistors. I have seen these in HF circuits.
I an early version I used the LT1016 as the comparator. The AD8561 simply gave a better sound.
Tieftoener said:Elso,
Hi Tieftoener,
- Digital Source
- KWAK CLOCK parts questions
