KW-AVX720 Head Unit Repair
I have a head unit that is not powering up, i cant get a image on the screen. it apears to very very similar to a florecent tube backlit tv. at first i thought it was a bad bulb so i soldered some wires onto the HV transformer to check for voltage but there is no voltage at either end.
almost all of the op amps have no voltage on any of the legs except for one of them
M 847
1228
has 3v on the bottom right corner leg in picture 2651. its the op amp almost right in the center of the board.
the power button on the front of the face. when i press it, the radio will beep, and when i had the dvd drive it was spinning.
i have checked he transistors on the board for shorts and have found nothing, and i checked all the caps and they all seem to be good. i dont have any diagrams and i cant find anything silk screened on the board for ribbon connectors nameing which voltage should be where.
any ideas anyone?
I think i have chased down something. I have enclosed pictures and schematics for where I think I need to be. my video driver circuit was all 0v so I chased it back to cable 11 on the ribbon out from the mainboard to the panel board. here is my measurments.....
A 14.6V
B 15V
C 0
D 14.4V
E 0
F 0
G 14.6V
H 0
I 0
J 14.6V
K 0
L 0
M 13.9V
N 0
O 0
P 14.4V
Q 14.4V
R 14.5V
S 14.5V
T 0
U 14.5V
V 14.8V
W 14V
X 14.6V
Y 14V
Z 14V
1 13.1V
2 13.2V
I am not sure if im even in the right part of the board but these resistors look burnt and there are meausing 0 ohms across the 2.
I cant put it into diagnostic mode because the screen wont light up so i cant verify for sure its on the radio, and I cant have the dvd drive attached when stabbing with my multimeter because I dont have a cable long enough, but everything else is hooked up. I can make an extesion cord if i really need one.
no there is no display at all with a bright light.
I assume there is a amp spike because the dvd in the drive is spinning. I blew the fuse for the amp circuit in my meter, i will get a new one asap.
It beeps on then the dvd spins then it shuts down, I can repeat that all day. what I cant do is eject the disc or shut it off.
Are the various toggle/control pins of IC721 toggling from 0-3.3v when you press the power button?
When you check for an increase in current draw, you'll have to wait for the CD to stop spinning.
It's better to use a current shunt resistor to measure current if you don't know for a fact that the current will be less than the current rating of the meter.
ey you did fix it or find the problem i got the same problem and when i checked the board i found a cap blown right in the center is aside the 6 leg chip
( M 847..... 1228)next to it was a cap blown just one, i replace it and still doing the same thing were i go now or were i look.....:confused:
