KSS-240A only Service Bulletin available but DS for the associated Mechanism wanted
For the optical pick up "KSS-213C" there are both the associated SONY mechnism KSM-213CDM, KSM-213QCS so as KSM-213CCM and the associated datasheets available on the web.
But I am not able to find the appropriate type number for the KSS-240A (KSS240A) mechanism and thus also not able to find the datasheet therefore.
The only papers, that I have, are the attached service bulletins from Sony (also helpful in certainly cases).
Who knows the right designation for that mechanism ??
Thank you for a hint.
About the KSS-240A I have found several threads here on diyaudio, but no one is helpful concerning an advice therefore:
http://www.diyaudio.com/forums/digital-source/160033-sony-ks-240a-focus-ok-signal-check.html
http://www.diyaudio.com/forums/digital-source/160668-sony-cdp-c433m-kss-240a-replacement.html
http://www.diyaudio.com/forums/digital-source/139605-kss-240a-based-transport-diy-player.html
http://www.diyaudio.com/forums/solid-state/137042-sony-fh-b7cd-kss-240a-problem-anatech.html
http://www.diyaudio.com/forums/digital-source/90009-kss-240a-pick-up-cd-player-parts-2.html
http://www.diyaudio.com/forums/parts/37863-replace-kss-240a-sony-cd-player.html
http://www.diyaudio.com/forums/digital-source/82612-troubleshooting-pick-up.html
http://www.diyaudio.com/forums/digital-source/81103-broken-arcam-alpha-8-trichord.html
http://www.diyaudio.com/forums/digi...ble-use-kss240a-cdpx55es-instead-kss270a.html
http://www.diyaudio.com/forums/digital-source/101935-denon-dcds10-cd-player.html
http://www.diyaudio.com/forums/digital-source/32730-teac-vrds-t1-cd-transport.html
http://www.diyaudio.com/forums/parts/39473-sony-mhc1600-hcd-h1600.html
http://www.diyaudio.com/forums/digital-source/100978-cdp-591-a.html
http://www.diyaudio.com/forums/digital-source/108381-sony-laser-arcam-mcd.html
http://www.diyaudio.com/forums/digital-source/159089-arcam-alpha-9-help-needed-6.html
  • KSS240A durch KSS390A.pdf
  • kss240a_service_bulletin_sm.pdf
  • KSS-240A HFP0428_®_.pdf
