I haven't done a KPS25, but I can tell you that the KPS20i did not have all three switches in the same position for each voltage. So, I can only say that if the unit is currently properly set for 120V, you need to flip each switch to the opposite position each is currently set.
Hi all,
I change the position of the input switchs and they unit power on and read frecuency error, so..... I pulled the eprom AM 27C010-120DC 5B and in the next day fix the 60hz .
Any one know if the eprom or the program is the same that Krell use in the Krell 400 integrated amp?
Anyone have the program?
Thanks!
Rubén
Thanks!
Rubén
