Kicker zx150.2
I got 2 of theese amps in for repair i believe they have the same problem.
Amp has no output.
I checked for rail voltage at outputs i have nothing .
I checked power supply fets with amp powered up black prob on chasis ground
Leg1:0
Leg2:13.92
Leg3:0
The reading are from the power supply fets IRF44's
wondering what to check at this point?
Ok i repaired a few solder joints on the rectifiers and now on the outputs i have 27.89 On the middle leg of tip 35
On tip 36 i only have 2.24 on the middle leg
tl494
1:1.08
2:3.64
3:.06
4:0
5:1.51
6:3.42
7:0
8:12.32
9:5.16
10:5.16
11:12.32
12:13.89
13:5.03
14:5.03
15:5.03
16:4.32
Ok the voltages on mpsa42's
1:-26.36
2:-26.36
3:13.85
I also found some 2n4401's in that same area witch i believe connect to the op-amps on the preamp board
and the voltages are
1:0.67
2:0.67
3:13.86
so then i tested all opamps and all measure
1:0.67
2:0.67
3:0.67
4:13.86
5:0.67
6:0.67
7:0.67
8:15.26
