Kicker zx 350.2 help
Alpine mrv-m500
im working on a alpine mrv-m500 class d amp
the problem that im having is that there is 50volts on my speaker terminals
i asked a buddy of mine and he sadie most likely its the driver ic
the driver ic i think says anaview.com
can i use a IRS20956S
is their any thing else i should check ?
anything else it could be ?
thanks
alpine update
i have a few of them and yea it seems like 2 power side outputs are bad irf3025
and 2 audio side outputs irfb4321 are bad in all of them
i think the part that i need is the driver ic
its a abletec.com 538p
if someone can tell me what i can use in its place
thanks
alpine ?
thanks perry and tom for helping me out
i was working on more of my alpine amps today and
ran into another problem i put my new power supply outputs in irf3205
and checked all of the gate resistors they all seem to be fine
but the amp is pulling a lot of current burning up my new parts
not shore what to check? or what it could be?
the parts that im putting in are good
Alpine mrv-m500 problem
im working on this alpine amp i had bad power supply ouputs irf3205
i go to put new ones in and the amp pulls a lot of current
i checked all of the gate resistors and they are fine
im not shore what to check?
the parts that im using are good
kicker board pics
i think the resistor that im looking for is a 1k resistor thats what the color code is if im reading it right
but one comes up as 130ohm way out of toleren and the other one is open reads nothing
in the pic i marked the resistors that im talking about there is 1 on each side
and the gate resistors around them are 150ohms
i think its a 1k ???
