I deliberated for a very long time on which speakers to purchase. There was a local Memphis dealer downtown in the city I live in, and also a Kicker dealer. The Kicker CVR 12"s that I was looking into were 199$ each. The Memphis Mclass subwoofers were listed at the other store for 199$ each as well. I finally decided that I wanted to buy the Kickers, because from what I heard Kicker had cleaner, harder hitting bass vs. other mid brands. So I got on the internet and did some researching, and mostly everyone likes the kickers that they have becuase they last and good. Found some on a site for $129.99 for 2 12" CVRs with 800 watt max and 400 watt rms. The amp I currently have is a Class D Mclass memphis amp.
Questions that I am asking are..
1: Is this amp big enough to push the speakers fluently. If not, what size should I get. Also, the CVR's are DVC. How should I wire these with my given amp, series or paralell?
2: Did I make a mistake here in my choice of subwoofers. I figured I was getting a pretty good deal here. My friend has a couple of Memphis PR 12"s, and they get loud as hell. And he's pushing with a multi-channel 400 watt PR Memphis amp.
I hope I'm did the right thing.
Also, I got a bigger box considering I have a f-150 supercab.
2 ft^3 per speaker. Is that good or should I go bigger?
cvr's are decent subs, but u would have been better off with the pr's..at the shop i part time at, we sell both and have done multipule switches from cvr's to pr's...same boxes, same amps and teh pr's are louder everytime. sound better IMO as well.
once u get into the L5's and up, then u get into kickers good stuff. i run a solox 18 daily in my truck. but i'd never own a cvr. i've owned several pr's as well...never stay long as ppl hear them and then buy them...lol...
what amp do u have? cvr's are d4, so unless u have the 1100d, u have the wrong impedence. with d4 u can only wire 1 or 4 ohm. all memphis d class amps, unless u have a pr series, are 2 ohm stable, except the 1100d, which is 1 ohm. if u have either pr series, u can go 1 ohm.....
to go one ohm, wire all positives together and all negatives together..then run to the amp. (doesn't matter if u run to one channel or two...it'll be the same impedence as all mono amps are internally "bridged")
to go 4 ohm, u'll take one positive and one negative on each individual sub and wire them together..u'll take the remaining positive and negative and parallel it with the other sub...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
