KICKER KX600.4
the trace that i'm following should be at or near ground right? i ask because with everything installed it will be at 12v and voltage is comming throught the 50v 100uf cap that i mentioned. the trace on the other side of that cap (12v) goes directly to pin 12 of the TL494 and a few other components. in the pics you can see the cap that i'm talking about above the fan plug. i bought these broken and it looks as though someone has tampered with them.
