kicker 352xi resistor
Hello
It is connecket to tl494cn (u01) on leg 8,12 and 11 and a transistor
The ic don´t get any power to start. The resistor is to the signal fron the radio.
In many of the older kicker amps, they use an NPN transistor to drive a PNP transistor. The PNP transistor delivered B+ to those pins of the IC via a resistor (between 33 and 100 ohms).
The PNP transistor (possibly a 2SA1023) would have the pin configuration of ECB (Emitter, Collector, Base). The transistor would have B+ voltage on the emitter. The base would be driven towards ground when remote voltage was applied. The collector would deliver voltage to the resistor when the base was driven towards ground.
If you need a sub for the PNP transistor, a BD140 should work.
I'd probably use a 33 ohm resistor unless you can confirm the value of the original. The ones that used the 100 ohm resistor generally had a zener diode connected from the resistor (also pins 8 and 11) to chassis ground.
