({ ... the story starts here))
dave tell me if i got this right, im just working out the wiring. i wana get 8ohm. each driver is 4ohm two driver in series is 8ohm?
and to change the watts, do i wire each set in parallel?
im going to need a lot of wire
Banned
Joined 2002
karma said:dave tell me if i got this right, im just working out the wiring. i wana get 8ohm. each driver is 4ohm two driver in series is 8ohm?
Looks ok to me.
karma said:i wana get 8ohm. each driver is 4ohm two driver in series is 8ohm?
If you use 32 drivers in the array, wire 8 in series (32 ohm) & pararallel the 4 sets and you end up at 8 ohms. Or wire 4 in parallel (1 ohm) & series the 8 sets.
Power handling is 32 x power handling of 1. Efficiency is about 14-15 db more than a single.
dave
planet10 said:If you use 32 drivers in the array,
That comes to 2.24m ~88 inches. Hope you have (at least) 8 ft ceilings
dave
Banned
Joined 2002
karma said:!!doh!!
I have a idea how you could have done this nicer and faster
Jase
Banned
Joined 2002
Banned
Joined 2002
Cal Weldon said:Why would you not just use three pieces of wood?
His idea is better
jleaman said:Table saw moveing the blade over after each pass. Do you have a table saw? Did you use a chissle
i used a axe chissle and table saw
Banned
Joined 2002
karma said:this is two piece the front and the shell, less joints to glue
stain it dark it pops
Hey look at those purple amps Thos mine ?
Banned
Joined 2002
karma said:those would be the ones
Maybe you can email me more pictures inside outside close ups etc etc ?
you can see pictures of the amps on my webpage under projects.
but my webpage is down i had to turn the server off, do to the security guard uses the same room it can get hot in there.
two weeks left of the school year for college, partys bigtime theres a kegger next door
- karma line arrays
