Karlsonator
Please tell me how important it is, if the size of the inside front is 11.8", not 12". I feel so comfortable making of the finished sheet of plywood. How to insert a photo?
.2" is unlikely to make any audible difference. Don't worry about it.
You can't upload pictures directly. You'll need to post them on some free picture hosting site. When posting to the forum, paste the URL link into your post using the little picture icon in the tool bar.
Oops! You're right. I didn't notice. It's the paperclip icon just right of the smiley face on top of the advanced compose reply box.
Testing 1, 2, 3,
With the Karlsonator, you can expect deeper bass extension, to about 50Hz, and generally smoother frequency response overall. The old Karlson original K8 designs tended to be very small, and had very limited bass extension. The Karlsonator was an attempt to come up with a design that met 'modern' expectations as to bass extension and had a smoother less rocky response, while still retaining the strong points of Karlsons with regard to good dispersion, low distortion, and subjective 'punch'. Obviously, since it's my design, I like this one. ;)
RE the K12: I 'heard' the K12/FE206EN combination on youtube, and from what I could tell it sounded great. Frankly it surprised me a bit. It has a larger front chamber volume. This is going to have more gain in the ~90-200Hz bandwidth, and not go as deep - I think. (it was never measured). I'd expect a rockier graph also. This may provide perhaps a livelier, 'pro speaker' type of sound.
I'm sure Freddy will respond shortly.
I don't have data on the Karlsonette/K12 other than a comparison of the Karlsonette and my "XK8" with the Tangband 1772. That showed 2dB->5dB more output with the Karlsonettte/K12 than the narrow K-coupler. If I remember correctly. both cabinets with 1772 had similar low frequency graphs. My graphs were done indoors and room modes were evident.
When comparing two venting methods in the 13.5" wide by 28" tall by 14" deep Karlsonator8 prototype, Greg B's method had the advantage but I think it had lower tuning (I did not make the graph below)
the Karlsonator8 prototype was 1.5" less in depth than the plan - my carpenter friend is cheap with materials :D
there is a lot of flexibility in making Karlson-type couplers - they can work well and sound very good.
either cabinet should be worthwhile with FE206EN
front of test coupler
Yellow = Karlsonator path venting
Green = XK8 vent
XK8 as built with lower vent position
Founder of XSA-Labs
Joined 2012
I recently found that if I get rid of the Karlson aperture and make a rectangular opening over the exit where the drivers are, you get a tapped horn. As such, the Karlsonator actually can have some pretty good duties as a sub woofer. Here is a 34 in tall x 7 in wide unit with dual 5.25 in Tang Band woofers. There is enough room to flip one of them around in push pull config to reduce distortion. Here is example with 37 Hz high pass filter and 150 Hz low pass filter applied.
Which segs into a thought, I've been having. I've been reading about Karlson speakers for the last few months. The part of his tech that I think I understand most clearly is the aperture. So what if a clam is made with a tapped horn slot at the bottom of the aperture cavity, right below the cone face. Has this been done, and were the results any good?
Obviously a clam with a tapped horn line behind the speaker. Would be large, I think, but then there are some mentions of longer clams in the literature (without the TL line behind the speaker) of clams with noses up to 1.8 meters long, I guess trying to get a clam to be anything but a midrange sound projector.
here's a picture - probably 20 years back of a klam subwoofer built by Wayne Neuser - think it was a 10" and employed a tunable passive radiator. The aperture was linear as it only covered bass - the little klam-sub augmented a total of 8-10" Scanspeak in aperiodic boxes. According to Carl it was pretty punchy, and the K-loading reduced the PR's excursion.
hey XRK971 - how would you go about choosing driver and klam chamber sizes for a passive radiator Klam-woofer/sub? Carl with their 10" driver sub-above said they used a 12" passive radiator and to try to avoid adding any weight. I get the idea it would look like a T15 but with PR facing up in place of the vent. The little klam sub above must have been decent to successfully augment 8-10" Scanspeak woofers. (Carl said is was punchy and had explosive power - I'll have to ask what they used for a woofer) Also, other than height, would a conventional Karlson shape with passive radiator be about as useful as the klam-sub? - the upper board would have to be long enough to fit say a 12" Dayton passive radiator for a 10" woofer.
can you modify the T15 model for PR without undue headache? - or would a PR-klam require starting from scratch to keep everything in order?
