john curl said:PMA, I hope that you can contribute something. I am at a null point at the moment, and blocked from going forward.
What exactly is it that you're wanting to move forward toward? Some new circuit topology? Better measurements? What?
se
john curl said:Steve, I would like to converse with fellow engineers on complementary circuit topology. PMA is up for this, Charles is as well.
Ah. Ok. Knock yourselves out then.
se
John Curl: "I would like to converse with fellow engineers on complementary circuit topology"
As far as I know, this is a DIY website where mostly NON-professional hobyists enjoy sharing and building audio gear. John, you take pride in intellectual engineering discussions, but when it comes to present hard figures or measurements of the Blowtorch, you just vanish or spread some more smoke to confuse people here. It's just ego-boosting and looking for playmates supporting your ego in an ongoing game!
You may go on and use those childish emoticons again in your response as you did the last time.
I dunno, courage, plenty of non professionals like me follow threads like this. (Almost 500k views of this thread). Lots of good info.
FrankWW,
You are right. Lots of good info, but when it comes to hard figures or measurements about this thread's topic, there is zero evidence. Look at PMA's request to actually listen to the BT. All he gets is a vague response to contribute more. He has given a lot already, so where is mr. Curl with hard figures, measurements, evidence??????
john curl said:There are many threads on this website. Why not shop there, rather than here, IF you are not interested in professional discussion? Does everything have to be brought down to beginner level, just because this is a DIY website, for the most part?
I agree, completely.
This forum and every single one of its threads is accessible to every member and every member has equal right to post in the topic of its/her choice if he/she has something to contribute, ask or explain.
While it is perfectly acceptable to ignore someone, it is against the fundamental spirit of this place to exclude others for whatever reason.
I’ve seen this happen on more than one occasion in this thread and I will make sure it stops.
/Hugo
Just as I expected; no figures or measuremens whatsoever! Just sweet talk to suit those that fall for it and, as it turns out now, are being used without even being aware.
Sad to see that this thread has turned into the playground of the "happy few" who consider themselves engineers, well educated and experienced with all the knowledge and rubbing it over and over in our face that we're not good enough to participate in their gentlemens discussion.
However there are still some who can see through this sharade and stick to their own opinions and discoveries. For the record, I'm not an engineer, but someone who intuitively discovers and explores. Sometimes I seek help, but most of the time I follow my own course which has been more than rewarding till now.
N-Channel J-FETs only
No suppression of second harmonics; does that harm?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=1794&highlight=
A perfectly working discrete circuit can be built with N-channel J-FETs only. Of course is not complementary...Steve Eddy said:Excuse me if this is a silly question, but, why the need for P?
There seem to be some good N channel FETs out there, but they're essentially rejected because they have no P compliment.
Is there no way at all to achieve as good or perhaps even better distortion cancellation using only N devices?
se
Those who want can learn here. One might not expect everything to be explained as a cook-book, there is a lot of high-value intellectual property. And, it has hardly been intended to make reverse-engineering and build a BT copy, DIY or not. This is the real reason why some here complaints.
Get this, and get this straight; I'm NOT reverse-engineering anything but try to grasp the function of a certain topology. I have not cloned nor built anything related to the BT. Furthermore I mentioned it here repeatedly that I do not expect any cookbook education here or anywhere else. Once more, I follow my OWN course!
I respect the intellectual property of others as such, but mere figures or measurements of a so called "unique product" are normal data which can be found in any respected audio magazine review.
I do not complain but POINT OUT that I have my own opinion which does not necessarily has to be in unison with the so called "thread owners" here. I don't have to be likeable either. Everyone in this thread is here for a personal reason, including you Pavel. You made your goal very clear some posts ago. Now why would you want to do that? Just think about it....
I see no need for measurements on the Blowtorch. Measurements do not tell much about sonics.
PMA has simulated a design that is very close to the Blowtorch,
and we have seen PMA:s distortion simulations. Good enough for me.
I even think that John said that PMA:s dist spectrum was close to the real thing.
I find that this thread has positively moved away from the Blowtorch design and into other stuff related to sonics.
Sigurd
Sigurd
courage said:Just as I expected; no figures or measuremens whatsoever! Just sweet talk to suit those that fall for it and, as it turns out now, are being used without even being aware.
Multiple choice quiz on logic
Which of the above is more than an blank, empty, unsubstantiated statement:
a) PMA's.
b) syn08's.
c) Both.
d) None.
PMA said:
John, just returned, and results of listening tests were great for discrete complementary - differential, against opamp based designs.
Originally mocked by syn08
John, just returned, and results of listening tests were great for opamp, against discrete complementary - differential based designs.
a) PMA's.
b) syn08's.
c) Both.
d) None.
- John Curl's Blowtorch preamplifier
