for the price of one nice F....
Broken tail-light replacement ratio will be much higher than 6:1
(I'm sorry, my jaw can't handle any car brand that starts with an F)
For a rip-off, it's a steal.
(my mom drove me in a ditch at age 6 in a F... Cortina, could be she was drunk. The Italian F.. look like shiny plastic dinky toys, with zero design innovation since the 60s. The Danish F... should be spoken of no more. The smaller/cheaper Italian F.. is for chicks and F..s)
For some hypercar willy waving Fastest Nurburgring lap times 2015 | Auto Express Bentley continental GT is over a minute behind. Even the ford focus ST is faster!!!!!
Hi Brad,
-Chris
Naks were very happy machines. There was an update to change the idler wheel for the fast winds to a gear later on. T/U tension was dropped to 35 gr/cm with the gear mod installed. That was valid for "standard mechanism #2". The earlier machines from the 480 and later were, you guessed it, "standard mechanism #1".I had a 300 for a while and was dubbing vinyl from a decent 'table, arm, and Shure V15.
-Chris
I love Sutherland railing against sockets and then having the gain setting resistor plug into a socket.
Maybe you can custom order it with the standoffs instead.
Yes, but in the Bentley you complete the lap in style.
Bentley Continental GT is garbage for the price. I have driven one a few times. Volkswagen parts bin other than the gaudy-but-nice interior. Weighs a ton, not very fun. Looks like an upscale Chrysler. If you buy one instead of a Porsche 911 you probably never test drove anything else.
Hi dvv,
Ever hear their car product? I still have a TD-700 (nice machine!), and maybe a locked TD-1200 MKII somewhere around here. That had a great FM tuner. Cassette was perfect on that one.
-Chris
Yes, and that is what makes it such a shame! The gear was capable of truly fantastic performance, but few ever heard it. Every machine we serviced created extremely happy lifelong customers. Similar situation for all CD players, most are not adjusted as well as they can be.but the end rsult for a regular buyer was still worse on the Nak than on the Sony,
Mine did too. Then I started servicing them and saw what they could really do. So much for the idea that they were just over-priced! I always wished that Nakamichi had come out with an open reel machine. That would have really upset a lot of people! But Studer & Revox do deserve their reputation. Everything was milled to the proper dimensions needing very little in the way of shims. Contrast that to any Japanese machine where everything is adjustable to make up for loose manufacturing tolerances. With Tascam I was always shimming multiple things to get it in alignment.my experience tells me there's a lot of perception here
The Dragon wasn't that great, really. The 1000ZXL was the peak of performance, and the 1000ZXL limited really did have gold plating in the transport. Given a choice between the Dragon and the CR-7, I'd go with the CR-7 I think. That's a BX-300 with auto-calibration.was a model quite below the DraGON STANDARDS
-Chris
You mean... worse than Volkswagen ?So they have been cheating for years.
Hi ticknpop,
There isn't much wrong with the 2N5087 and 2N5210. They didn't match them for one, and surrounded the transistors with Philips components from Electrosonic. Open a 4B and an Electrosonic catalog from the same time period. You can find each part they used. No soft start and a defective bias control circuit meant that you had to leave the amp on all the time, or replace power switches and wait a 1/2 hour for the outputs to become biased near where they would end up. They were class C for a while before the bias came up. Junk.
I hear they make real amplifiers these days.
-Chris
Bryston was complete garbage until they hired a real engineer. The stuff failed all right, they kept it quiet with the 20 year warranty. They simply included the costs of repairing a percentage of equipment with the selling price.20 years of 5210/5087, steel leaded metal film resistors, aluminum electrolytic interstage coupling capacitors (often 4 to 6 in series through the signal path), a single pair of 7815-24/7915-24 regulators for an entire preamp or processor, ceramic hf bypass caps, standard diode bridges, - or it's surface mount equivalent - all the ingredients for mid-fi at it's best
-Chris
Looks like an
There's two pre-2011 in my street, already look very dated.
On the other hand, the new 4-door FS in champagne/champaign metallic, most balanced Bentley design since the S3 saloon of the early/mid '60s.
(James, I'll have my tea with a dash of milk and a raised pinky finger)
One of their claims to fame at least in the old days was their complex composite output stages, which appear in simulation to be the devil to compensate.Hi ticknpop,
-Chris
Funny story about the Brystons. Harman had a hand in equipping a Cinerama theater in LA, and used the "second-label" Proceed amps from Madrigal. I never heard one or saw inside one, nor knew who did the design, but they were probably o.k.
Someone with golden ears heard the system and complained that it sounded awful. Harman wound up replacing the amps with Brystons and it made the guy breathe a sign of relief. Of course he was told beforehand what had changed.
This was quite a few years ago.
Paraphrasing from The Big Lebowski: "You need a finger? I can get you a finger."(James, I'll have my tea with a dash of milk and a raised pinky finger)
They actually oscillated so badly they toasted the power supply capacitors. Their solution was get a specially made capacitor that took the heat without quick failures. A lesson in why you need a wideband scope or rf probe to really check circuit stability.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
