Derfnofred,
Personally I would have no trouble with DBLT and think it is the only way to truly subjectively compare two systems. Yes a nice looking piece of equipment sitting in your room is nice but that is another story really. I have seen some really nice looking impressive equipment at the Stereophile shows and CES shows I have exhibited at that sounded like dreck, so I give appearance little attention besides just liking someone's attempt at visual design. You can see that every day with the number of purchasers of Apple products, sold on the looks and great marketing, the technical and build quality of some of what they have done in the past is totally ignored.
Waly,
While on a technical side of things I agree with you that if you don't understand the basic concepts of electronics to go and design an amplifier or any other audio equipment would be fairly stupid. On the other hand you have those who's only objective is to listen to the best sounding music system, at least to their personal tastes, and then those people really could care less how you created the electronics. I think this is where all this back and forth comes from, the problem rears it's ugly head when those who don't understand the underlying electronics try to come up with fanciful reasons for why they think this or that amp or whatever sound better than another. Feedback seems to trip up so many, the concept that feedback can work at the speed it does and not cause problems that inherently seem to exist is beyond simple comprehension. Physics is physics is physics, and no matter how much we learn that never changes, just or understanding.
I couldn't agree more. If the golden ear brigade would keep things to a personal preference, then I guess nobody would have a problem with that. However, usually it gets to the point to which "I have a secret sauce that makes my designs special", "you don't [know how to] listen", "you don have experience [whatever that is]", etc... Those who don't care on how audio is build have no relationship with a DIY site.
Concerning power amplifier slew rate requirement and vinyl. Cartridge output is stylus velocity sensitive, eg 5.6cm/s = 1V, therefore cartridge output slew rate represents stylus acceleration. Cutting limits acceleration to c 1000G peak, ie 1000*981 cm/s2, ie a slew rate of 0.12V/uS (divide by 5.6cm/s and substitute for 1V).
If a power amplifier output of 1W into 8R represents 0dB (5.6cm/s), amplifier output slew rate corresponding to 1000G is then 0.12V/uS * 2.82 ie 0.34V/uS
That is to say programme material for vinyl playback won't demand slew rate more than c 0.34V/uS per watt at 0dB level ???
Then it seems moot to consider power amplifier slew rate to be limiting factor. it will seldom be tested even allowing for significant headroom.......
Is this correct ?
Seems OK to me. Also nicely jives with the rule of thumb that you'd like 1V/us/pk Volt Vout. So for 100W into 8 ohms that would be 40V/uS, which includes a very healthy safety margin.
Jan
Just don't try to rationalize it, because that's where one gets into trouble.
So true!
BTW I like the Kolinummi book.
It has some interesting perspectives, doesn't it?
I found it as a dissertation and immediately decided it had to be printed and published.
Jan
Brad,
Is that book only available from Elektor?
Linear Audio
I got my copy from Linear Audio Press (the publisher). I don't know if it is available elsewhere. ISBN 9789490929091. It's stated that it is based on the author's dissertation ("thesis"); he was awarded a degree in 2010.Brad,
The author focuses on low-distortion open loop behavior, but touches on a lot of stuff, some of which is elsewhere, naturally. The 291 references do have repetition as he assigns a new number every time one appears in the text, but that works fine I think.
The author's conclusions are bound to be controversial, but he has done a lot of work including a good deal of experimental stuff. I have only jumped around in it so far.
In particular, I admire his admissions about things that are not proven, despite the temptation to think they support his approaches. Also his frank assessments of the drawbacks of various of his prototypes are refreshing. He mentions that nearly 200 prototype circuits were constructed, some only fragments of overall amplifiers---but that is still a lot of work.I've done the same but have probably read most of it at this point. Once you've absorbed Self and Cordell, then this book will broaden your perspective a bit. Fine work by that young man.
I also like his treatment of thermal distortion. He can hardly be expected to know everything already, so not knowing the origins of certain circuit techniques that predate their application to audio is understandable, and not cringe-worthy.
cringe-worthy.
For me that's a memory-candidate.
Waly, If you haven't read Ron Quan's latest paper on induced phase and frequency modulation, then you are still in the dark about such things. #8722
NMD (Name Dropping Brigade), nothing relevant to this topic. Nobody said PIM doesn't exist.
That, Waly, comes from the fact that I can actuallly hear the differences without having to measure anything, in complete contrast with you,
who hides behind his degree that in fact that you can't. I still do measure, without fail every time, because I'm curios in general regarding
what it takes to her the differences, if any.
You have not refuted any one of my beliefs, right or wrong. Must be because you can't, even if you have a degree in electronics,
and I indeed do not. Nor do I need it to hear or not hear this or that, that seems to have no meaning to you. You have no idea
what you're missing. I pity you. Over and out.
I've heard audio differences easily and clearly, as early as 12 years old, which was about 10 years before receiving any
electronics training or degrees. I didn't even want to hear such things, instead I just wanted some good music.
John,
Have you personally read Cordell's book which does talk about feedback and the speed at which this is happening? How can feedback cause a time shift in the audio time frame, that just goes against the physics again. You might as well disregard the use of the LTP as a differential circuit if your going to look at feedback as a problem.
How about negative feedback "Time corrupting" an audio signal? That is what my mentor just told me. Any thoughts? '-)
Yes, hogwash in its purest form. Feedback chasing its tail, one of the most common misunderstanding of feedback and it's mechanism, your mentor needs a good undergraduate EE course to refresh his knowledge. Essentially a confusion between phase and group delay, why do I suspect you already knew that and asked only to, once again, stir the pot?
My father was self-taught in electronics, beginning with being an amateur radio operator in Idaho. He did a good deal of audio, including speaker designs, as time went on. Late in life he tended to disparage his ability to hear very well, and partly because of a deep-seated conviction that he was disrespected by his children and the audiophilic pretensions of one of them (not me), he tended to discredit any claims made for equipment that could be considered high end. He also suffered from fairly severe tinnitus.I've heard audio differences easily and clearly, as early as 12 years old, which was about 10 years before receiving any
When CDs came into currency he would protest that he wouldn't be able to hear any improvement other than the absence of surface noise. I made some cassettes on a decent Nak deck from CDs before he finally got a player. Some of the source material was from the days before digital audio improved and people began to appreciate what was required for CD mastering. One recording in particular, a CD with Dimitris Sgouros playing the Rachmaninoff 3rd piano concerto, had some disturbing artifacts, although fairly subtle. He detected them immediately, despite wanting not to.
^ bump this.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
