Is there any kind of resistive sheet with which I could get 1R or more resistance between two metal surfaces clamped together? I thought the graphite thermal insulators might work but the datasheets give very low resistance values.
The black antistatic foam is fun to play with.
Yeah I'll rerun it Thursday with a different bridge. But if the capacitance reading is staying the same so should the inductance.
I have a bigger problem, what makes the distortion voltage? The voltage across the wire is ~0.1% of the voltage in the loop (if the AP is 600 Ohms) which increases what you are looking at by 60dB. At higher impedances the distortion of the voltage across the wire as a percentage gets enormous. What you are looking for is just not well posed.
Tin, steel, or nichrome might work
Hum.Switching supplies are usually VERY NOISY.
According we were talking about power amps, what kind of noise ?
Ripple ?
Diode switching noise VS frequency leakage, and what about their frequencies ?
AC isolation (currents in ground connections, specially when asymetrical) ?
If you cannot measure differences in distortion neither hear any noise out of the amps in absence of signal, what is the point ?
That is a good question! The distortion is as mentioned -110 or 50 dB below that which would leave the mechanism at .01% into a 10k load.
Do you have any thin magnet wire to try it yourself?
I'm thinking of it being used clamped between two metal plates with say a cm or two of surface area. A ring of resistive wire may work, but nichrome isn't resistive enough, and I don't know about tin or steel.
I'm thinking about velostat:
Pressure-Sensitive Conductive Sheet (Velostat/Linqstat) ID: 1361 - $3.95 : Adafruit Industries, Unique & fun DIY electronics and kits
But I'm not sure how to calculate the resistance. It would be ideal if I could adjust to the resistance I needed just by increasing pressure, but I'm not sure how to calculate the resistance I need and how pressure would affect it. What I want to know is how much surface area would I need to get 5R between two plates, and could I adjust this within the right range using pressure?
I have a spool of #30 and a drill and jn's current sensing resistor, I'll see if I can try this weekend I have an idea to improve the sensitivity. Let's keep this fun.
Still no response on my thought about two ways of twisting? Imagine the insulation having an identifying stripe running along it, which always has the same orientation along its length, ie., doesn't spiral around the conductor: in twist 1 the stripe always stays, say, on the outside of the twisted pair, is always visible - this is what will nominally happen using a drill; in twist 2 the stripe spirals to the inside and outside of centre of the twisted pair, but from a distance the stripe constantly faces a certain direction.
The 'stress' on the cable is different in the two cases - does this make a difference, in any audible area?
Wow we agree on this!
I did break a few wires learning where I went too far.
I'm thinking of it being used clamped between two metal plates with say a cm or two of surface area...
If you put a compliant conductive layer between the resistive sheet and the electrodes and the resistive sheet is essentially incompressible (i.e., hard plastic, not rubber), you can minimize the resistance change with pressure. Otherwise you'll have a surface area effect and a volumetric effect.
To calculate resistance, you need the resistivity in ohm-cm. Multiply by thickness, divide by area.
Here, some measurements L.C did with the Connex that Scott talked about.Well, today I tried to test an amp that uses switching power supplies. It overloaded my HP39 analyzer. That is too much.
http://www.diyaudio.com/forums/vend...e-mosfet-amplifier-module-40.html#post3882608
L.C First One (A simple current feedback amp, and, as it, with less PSRR than a long tailed pair) has something like < 0,0016 % distortion (at 1W) and >110dB signal noise with Hypex Smps.
Often, commercial amps with SMPS are cheap, may-be not a good idea to generalize
It would be interesting John, if you can compare your listening impressions with your favorite amp with an Hypex SMPS VS Linear...
I think the thinner the wire, the greater the affect.
THc-RNMarsh
Bruce Hofer has developed a measurement filter for class D (and by implication SMPS) to avoid this kind of issues. It should be on the AP website. They sell them at AP prices but should be possible to home-brew.
Jan
I didn't check but am pretty sure his SR1 has an internal measurement filter for things like this (even an AES17 would work) but you also need an external one to avoid overloading the analyzer input circuits.
John why are you using an HP39 (339?) instead of your new toy?
Jan
Jan
Yeah, right .. if the equipment can't meet the specs, change the test conditions
You know this equipment? Can it not meet its specs? What spec are you referring to? I'm in the market for something like that so am interested.
Jan
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
