I suppose I should stop using my mouth as a third hand for solder. Probably explains a thing or two.
Start worrying when you see your underarm turns blue and let Brad worry about the smaller doses
I was well below the levels considered to be dangerous, but about 1/4 of the lead in my blood was indeed from the solder
I was a little more careful to have the fumes vented away after that.
No, wait. He is done by mercury. Lead can’t do any worse on him.
I once swallowed the mercury in a thermometer as a child
I like to attribute my slowness to mercury too. Lead/rosin fumes is too soft a medium (but what a smell!!).
George
I believe! Therefore I can work outside of established parameters. You could never have walked my walk, and have even remotely comfortable, SY.
What the heck I find it hard to think that this was in response to that
Only those with no particular knowledge of chemistry and a willingness to believe quacks.
George
Gpapag, let me explain. I attribute my ability to move forward in audio, based significantly on believing in a number of 'interesting individuals', trying their ideas, and keeping open to the ideal that most people I meet are for real, and not engaged in cheating people.
So, I might believe in acupuncture, accupressure, or a chiropractor's manipulation IF it might or does get results. I do not think of this as quackery, for example.
I believed in extra vitamins when my doctor did not think it very important, and I cured myself. Whatever works! That is MY code. Not whatever fits my belief system.
But your circuit topologies are yours, you should give yourself more credit.
I'm proud of what both of you just said
Well now back to audio design. Aero, since you are still here, this is what I would recommend that you make a version of: It is essentially the same thing as the JC-2, but with 1/2 the parts. You can buy boards for it on E-bay CHEAP!
I'm on it Boss...I will get back to you.
If I can help somehow, I'm just down the road. (And in the LR phone book.)
Chris
Thanks Chris, I appreciate that very much
as the old saying goes, we probably know some of the same people.
Try 1.
Mr. Curl,
I can't see the traces of course, is that both channels?
great...didn't think so, but the schemetic was partially cut off. I guess I could have counted components though. Glad it's two boards actually.
OK, I'm a gamer for this.
So, I might believe in … I do not think of this as quackery, for example.
Mr. Curl.
That initial
has sent me to the opposite direction from what you were really meaning.I believe
Thank you for taking the trouble to explain.
I find that being good intentioned –although may kill one financially-it is essential for a healthy relationship with our inner part (and thus the rest of the world).
Being suspicious over anybody/everything, works as a poison.
George
John,
The Jim's audio boards I got are blue, will that make what I play sound kind of blue? Affect component values? I like the Blues - Buddy Guy, Willie Dixon, Muddy Waters,
They also have Borbely's very good jfet/fet shunt regulator boards, but some devices are getting hard to get for it such as K170/J74 and J148/K982
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
