JL AUDIO 1000/1
Got 1 of theese in for repair. Its missing some parts. Wondering if someone knows what parts go in the following locations and have any part numbers?
D81:
D810:
D809:
D808:
C831:
C829:
C827:
C832:
C830:
C828:
Then between the caps there are Resistors I believe they are 1210 package there are a total of 3 1 is missing and the other 2 are out of tolorance.
Heres a pic:
See attached.
When working on the JL amps, I tape the boards to the top of the capacitors (the LEDs drop between the caps). This keeps them out of the way and prevents them from shorting out to the main board when working on the amp. If you look closely, you can also see that Goop has been applied to the wires to prevent stressing the wires at the point where the insulation stops. This prevents them from breaking.
