I've got 3 kits on the way (lm3875, lm3886, lm4780) to be used eventually as the amps for 3-way active front speakers (once i've worked out the system configuration).
To start I will build them as straightforward stereo amps, with attenuation, to allow comparison, trial of different attenuators etc.
Here are some pictures of my layout scheme for comment.
I've bought a sheet of 10mm aluminium, and have access to a milling machine and a sheet bending machine and plenty of thin stainless sheet.
3 amps:
3 amps:
The idea is to have separate power and amp compartments.
Lid and base will be removable to allow assembly/modifiaction of the 2 section.
The lid/base will be sheet metal bent into a simple C shape, the chassis will be held together by M4 socket screws in counterbored holes. The dividing middle 'floor' will be fixed from the inside.
The front/rear panel will be milled down where necessary for fixing of sockets.
10mm Al sides for heat sinking, and a width of 140mm were the design drivers.
Jimbo, you may find this gives you some ideas!
http://www.metalfast.co.uk/ would have cost about 60quid for 1200mm x300mm x10 inc vat and 15quid delivery. I got mine via my brothers company for the same price.
Once again I was tempted to buy in bulk 'just in case' because of the delivery charges, so I nearly bought sheets of 8mm and 6mm as well.
- Chip Amps
- jimbo's chipamps
