JFET input, MOSFET VAS, LATERAL output = Perfect!!
I'm still not sure we need a servo yet - if you don't mind a little drift. I'm going to buy a multimeter today that has datalogging capability so I can measure the DC offset every second for an hour and see how it changes. It will be interesting to see the graphs when it's done.
Yes quite possibly. I found that the oscillation didn't help the sound quality at all.
I bought a multimeter yesterday with logging capability but can not get it to work with my computer as it uses an old school rs232 serial cable and software made for win98. Bought a USB to serial adapter but no good. Taking it back today to swap it for s USB one - if they have any.
I think I'd almost rather go back to a ltp input if it proves too difficult to get it stable without a servo. I'm interested to hear what people think about your jfet servo idea though.
Well, from my side, when I finally can get around to building this amp, I will not sacrifice either the single i/p transistor or the the DC coupling - so my drift issues will be considerably more that you are dealing with now but this may be helped by the fact that I am aiming for a fully balanced working system so hopefully my two amps will drift together.
But Tim Andrews has demonstrated that reasonable drift & DC linking are possible and in my experience there are great sonic advantages across the whole frequency spectrum from avoiding any kind of caps ( or transformers ) in the signal path and I tried some fairly expensive film types but confess to not try Teflon caps yet - the extreme cost put be off !
DC Offset
All,
Here are the DC offset results. Test interval is 0.5 seconds for about 50 minutes into a 7 ohm resistor. As you can see it did stabilise at about -20mV at about 7min or so...but I wonder what the hell happened to make it drop from +325mV or so!? I will have to test again and confirm if this happens every time.
So what are your thoughts regarding the need for a servo or other offset control? I think I could now readjust and have it stabilise at +/- 10mV, but the high offset on power up is a worry.
Greg.
Hmm, interestingly the big drop at 7min can be induced instantly by touching the input. It would seem that when the amp is first turned on with no source attached it is in some kind of metastable state, and just the slightest stimulus can make it stabilise. Probably even the noise from a source would be enough....
Maybe no servo is needed?
okay... uhmm I was about to comment on the design on the first page when i realized that the thread has 32 pages! And the last schematic does not look like the first one at all.
Am i missing something? :warped:
What i wanted to say. Many years ago i build an amp looking close to the first one. Except that i used mosfet in the inputstage too.
The ZVP3310 capacitance changes a lot accross the VDS range.
The sound was not that good in my opinion compared to my CFB designs. (yes there are several designs).
A bit to dark side. Details was there but it was not neutral at all.
No problem.
I am trying to locate them right now.
First two of them. They are CFP amp both of them.
The 2037a2.pdf
We have listened to the 2037a2 but it will suddenly oscillate. It is the CFP output stage.
But it is very vivid amplifier to listen to.
http://sitosite.dk/amps/mirand-a1a.pdf
The Mirand A1 V1.1 is very neutral and goes very deep. One of the guys from denmark has it running instead of an Advantage integrated amp (I think it is an i200?!). It outperforms the amp on the level of detail and ability to deliver power when needed.
The bias current is only 100mA, and it does not change the sound a lot in the warmup phase.
  • 2037a2.pdf
