JBL4607 4507 port mod, w/wo 3015lf
OK, what is the max HxWxD o.d. dims you can can live with?
BTW, what are the Kappalite's specs? I just noticed I have several different sets and they're not close enough to just use the mean. The most conservative set dictates at least a 10 ft^3 cab to get down to 40 Hz.
GM
Hard to accurately say without actually packing the car. I could probably fit the
4607 type pair in there, probably not a pair of ss15, maybe a tham15 pair.
There's the fearfull cabs too but I don't expect a belly button thump out of em as I had a cab almost exactly like that and it had no "cahones".
The ss15 was my first choice,fyi. I'll probably use them with my Elec drums
as well when I play out as a drummer.
10 cu ft!!! Maybe I should just put a baffle in my hatchback and pull it inside the club :D
OK, so ~6.53 ft^3 gross or ~6 ft^3 net and if no actual measurements are made, then the design would have to be made based on a worst case set of specs and if a 30 Hz tuning is desired, then there's going to potentially be power handing issues since one set of specs has a 44 Hz Fs.
GM
Hi screamersusa,
Post #25: "...whip up a couple of tham 15..."
I looked at the 3015LF in the THAM15 a while ago. I would not recommend it. When you are going that small w/ the 3015LF it creates a nasty looking bottom peak, and will need a high pass filter around ~34Hz; after that the response will be down 10dB @ 40Hz. You should get better response and extension w/ your 4507s.
Hi screamersusa,
That's why jbell designed the SS15 w/ 1/2 plywood.
What you might want to do is rescale the SS15 and the THAM15 to fit your 32Hx21Wx20D box dimension, and then see what the result looks like in Hornresp. A rescaled SS15 would probably have a very similar response to the original SS15, you would have to fiddle a little w/ the baffle board(s) to make the 3015LF fit because of the reduced depth.
A BR w/ your basic dimensions may still be your best bet.
Regards,
I don't see it as an issue since there's considerable acoustic damping of this peak in high power apps, but blocking off S1 to 0.01 cm^2 and damping segment 3 with some polyfil apparently solves the problem good enough, at least for me:
GM
TB46 If I toss two 4507 sized cabs together as rear loaded (speaker mounted inside, back removable), What would be the right size assuming I'd like to use either One rectangular port or a slot type on the bottom for ease of construction instead of 4 4in round? I figure you have the data already in whatever proggie you are using.
Would round ports around the woofer make that big a difference in a sub only application????
I'm thinking rear loaded so I can use a solid fabric grille.
Plan on going to HD for pre-cut wood mon or tues.
Probably worth noting how they will be set up.....
I have 4 pv15 modded... Normally I'll use 2 at full range, lows rolled off as needed.
These subs will ADD to what lows are already there so a BR box makes sense.
So I'm filling out the low end on the pv's not replacing it.
I may mod the mackie crossover in the 1400i to 65 and 80 rather than 65/125.
Hi screamersusa,
Can't say that I quite understand what exactly you are going to do. But I think you may be suggesting sticking two 4507 enclosures together to give you a big vented enclosure w/ a slot port?
I messed w/ the drawings, and have two examples, one w/ a normal port, and the other one w/ a larger port that takes up a lot more internal volume.
Hope this is what you are looking for. Put the Hornresp Input screens into Hornresp, and you can see all the details.
I won't be able to spend any more time on this, so I hope some of the other guys can help you out.
Regards,
  • Dual_4507_Single_3015LF.pdf
