I picked up a pair of JBL s99 Lancer. The gentleman that I bought them from was the second owner and he bought them in the early 70s. The former owner admitted to "rocking out" when one of the the tweeters stopped working from that point they set stacked in the corner.I
-The foam on the JBL LE-14A woofers are whole and yellow but stiffer than a gentleman over using viagra. So a refoam kit will be ordered for the woofers.
-I also want to completely revamp/update the crossover network. I may sale the current ones. If you guys can I will need some spoon feeding help with the cover design and what I wil need. Thanks in advance.
-On to the tweeters...I have a set of minty Peerless HDS 810921 large formats that I've used years ago in a sound quality car stereo from stage. I'd really like to use them but only if DIY thinks they will synergize well with the JBL woofers.
Peerless tweets ..
Peerless by Tymphany 810921 Peerless 1″ tweeter | Loudspeaker freaks
Electrical Data Nominal impedance Minimum impedance Maximum impedance DC resistance Voice coil inductance T-S Parameters Resonance Frequency Mechanical Q factor Electrical Q factor Total Q factor Force factor Mechanical resistance Moving mass Suspension compliance Effective cone diameter Effective piston area Equivalent volume Sensitivity (2.83V/1m) Ratio BL/√(Re) Ratio fs/Qts Power Handling Zn Zmin Zo Re Le fs Qms Qes Qts Bl Rms Mms Cms D Sd Vas F 8 ohm 6,6 / 58 ohm 11 5,6 0,0 700------7,00ohm ohm mH Hz Tm Kg/s 91,26 dB 100h RMS noice test (IEC) Long-term Max Power (IEC18.3) Max linear SPL (rms) @ power Short-term Max Power (IEC18.2)-
I'll keep the cabinet but clean them.up a bit. Power will come from a Dynaco ST400.
I'm eager to.see what you guys think.
i appreciate any and all tips.and advice especially regarding to Xover design and where to.order parts.
Carl
Peerless tweets ..
Carl
