If you remove it, does the amp stay in protect mode?
Have all transistors tightly clamped and have a current limiter or a 15 amp fuse in the B+ line when you apply power to the amp with that transistor out of the circuit.
it has a red dot in the lens you can only see it up close , so just my glancing it looks as if the protect light isnt on , im guessing it took a lil bit to charge the caps
