JBL 2226H 30 hz "horn" i built
JoshK don't think twice about Faital Pro I will be using them as soon as the plans are available, I think they are the best now from Italy built wise and reliability and sound wise. I have heard them in double 18" BR cabinet in Miami from a sound company last year for a Band/DJ show, it ran flawlessly for 18 hours continuously all night till morning (18XL1600).;)
No TH_1819 build ? with 18XL1600 driver it is still one of the best subwoofers I have ever heard :)
Hi ZivkoF, I am still 50-50 because the Faital 18FH500 price can't be beat it is a very good design for the output. I like the 1819 for it's size and simple build, still looking for a better driver since the 18FH500 may not be strong enough for the rigors of PA use. Any other suggestion like the faital 18HP1060 driver would this work to 30Hz? Since this is a stronger woofer than the 18FH500 for the TH1819? thanks!
Hi djlivex,
the Faital 18HP1060 will work just great to 30Hz as at 2Pi sensitivity is 96,51 dB @ 1w/1m and SPL it is only down -6,63 dB @ 20Hz (89,88 dB) and SPL is 97,32 dB at 60Hz.
FreeCAD is fantastic! A bit buggy but very very nice to work with.
Good work. I just watched a youtube video of someone using this software, and I have to say it looks to be quite a pain to use. Sketchup is still free and there are plenty of tutorials to get you going.
Trimble SketchUp
Pretty soon I will post new CAD drawings by request from Robert in Canada. Until then, here is a Hornresp record for a cabinet 1200 mm high, 900 mm deep and 600 mm wide.
ID=48.20
Ang=1.0 x Pi
Eg=44.72
Rg=0.50
Fta=0.80
S1=270.21309727863604
S2=397.43180524066366
Par=19.6
F12=0.00
S3=1106.2998813084603
Par=108.50989721764327
F23=0.00
S3=1114.6080003222314
S4=1676.383376699943
Par=83.79658021842297
F34=0.00
S4=1688.9727232610746
S5=2200.0
Par=88.5
F45=0.00
Sd=880.00
Bl=19.2
Cms=1.59E-04
Rms=5.0
Mmd=84.56
Le=1.75
Re=5.30
OD=1
Vrc=171.05910950361348
Lrc=50.00
Fr=100.00
Tal=4.00
Vtc=0.00
Atc=0.00
Pmax=100
Xmax=5.0
Path=0.0
Mass=0.00
Re'=0.00
Leb=0.00
Le=0.00
Ke=0.00
Rss=0.00
Rms=0.00
Ams=0.00E+00
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
Comment=JBL 2226 parabolic 4 sections
FILTER
0 0.01 0.0 -1 0 0.01 0.0 -1 0 0.01 0.0 -1
3200 25 0 0
40.50.50.5
0.50.50.50.5
SSSS
0111
1011
0022
0111
111
000
Uploading old pictures
More old pictures
Even more old pictures
This is a very appealing folding solution from a DIY perspective, just as elegant as it is simple, just rotate a square within a square, brilliant, I have been toying with the idea to have the driver access in the angled mouth panel thus adding a bit of length (roughly 400mm in the 15" case) to the horn, the box will become bigger if everything else stays the same so some tweaking is in order should one pursuit that idea.
I know this has been our for a while now, but it still is worth attention in my opinion, thanks for sharing.
