Folks
I have quite a few of these transistors (IXTH20N50) that were purchased for another project. This weekend I will have the exact count and will post here.
Since I have no immediate use for them, I would be willing to sell them for a lower cost than what Digi-Key is charging and without the quantity restriction.
I will only keep a few for myself so I can try this amp.
Shipping will be at cost via USPS.
Regards,
LS
Since i'm always into parts right after the groupbuy ended i'm very intrested in some of yours.
I already purchased some 300Watt light bulbs some long long time ago
Where are you guys getting transformers with greater than 60V secondaries?
Pretty much any shoddy AB amp from the 80's would make a great parts unit.
I have 2 transformers that would fit the bill. The old signal 88-8 from my old A-40
can be tapped at 66v @8A or the transformer from a Dynaco ST 400 has a 130v center taped secondary. Now for a 70v supply a 220 to 110v transformer could
be wired as a step down transformer for 55VAC which should give about 70V dc
after the bridge and crc filter. Just be sure it's a transformer and not an autoformer.
A comment like "train your ear" together with Fig 12 of the De-Lite article suggest that this train is leaving the station. I am getting on-board.
Antek - AN-15468
Antek - AN-6468
Those are dual 68 VAC secondaries at 800VA or 1500VA with a 12 VAC and an 18 VAC winding thrown in. A 75 VAC (Fig. 10 of De-Lite article) toroid is available from Antec but the rectified voltage will push a 100 VDC cap. No? I have not had much luck sourcing capacitores at 25,000uf or greater at 100VDC or greater. In fact, I gave up and bought 4 22,000uf at 100VDC.
Hopefully a 160-180 VDC voltage swing is applicable when the De-Lite evolves toward a dual-polarity supply. In the meantime, the 1500VA toroid could support a dual mono of Fig. 10 at approx 80-90 VDC. A belt and suspenders for the future.
Does anyone have a schematic that illustrates using a second 50D2 as the current source?
I'd be in if anyone can lay hands on some IXTH6N50D2
I dont mind trying another group buy for all these units again. Looks like about 100 of each is a good goal to get some preferred pricing. Let me me know if people are showing interest already in gettign some different chips. I will also throw some SemiSouth R100 devices into the mix, so people can get some of those to play with. It will give me something to do with all of those bubble mailers.
It seems I can no longer read component codes...
Sorry, I thought I had about 100 IXTH50N20 units, but what I have are the IXTQ50N20 transistors.
My bad...
Folks
Regards,
LS
My bad...
Here is a sign up sheet to start.
https://spreadsheets.google.com/ccc?key=0An3nVM43ZbQndHVfQWxMQzNFNmFlYndDWmREa1NtaUE&hl=en
I have also started a new thread on buying of both D_FET types.
http://www.diyaudio.com/forums/grou...emisouth-r100-jfet-group-buy.html#post2085063
- Group Buys
- IXTH20N50D Depletion Mode Mosfet Group Buy
