ive run out of room can i put the port outside the car?
Hard to design anything definite without the TS parameters, but I'm thinking if you make a bandpass system, you can put the whole box outside the cab, and just run the ports in.
sure here you go. i found them on kickers website i have the one with dual 4 ohm coils. 12 inch
i have rebuilt them with new coils and i have to take new measurments but im sure that these specs will be close enough for modeling. i dont have use on the new coils and i want to use them for a bit before redesigning a perfect box.
  • L7_0.pdf
That's the same info I pasted on Post #15. I was refering to your measured T/S.
